1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
09-05-2008, 12:02 PM
NY
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Victor Jr manifold clearance...
Is anyone using a Victor Jr manifold with a 351w? If so, what kind of air cleaner will clear the hood or do I have to order B&B's taller hood scoop? Thanks...
Mike
09-05-2008, 12:13 PM
California Dreamin Member
FL
I run an Air Gap, which is basically the same height as the Victor Jr.
The Edelbrock 42364 fits perfectly under the scoop.
09-05-2008, 12:37 PM
OK
Get you a drop base air cleaner with a K&N filter top. The whole thing will cost you about $60 at a speed shop.
Clois
"Let's roll"
"Be part of Something Good
09-05-2008, 03:21 PM
AZ
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
The lower price Cobra oval with the cast top and sheet metal base fit on my newer Superformance with a taller air filter. This particular filter has about a bit more surface area compared to same height smaller ovals if that's a concern. The car made 475HP at the wheels with that filter on the car. I didn't try it with it off though.
09-05-2008, 03:28 PM
FL
That filter won't fit under my hood, even with a narrow element.
09-08-2008, 10:21 PM
Wa
Cobra Make, Engine: B&B 5.0 roller W/carb & T-5 WC
Reason: delete
09-09-2008, 07:29 AM
AZ
Your filter looks taller than mine, probably better flow and same surface area anyway.
09-09-2008, 09:02 AM
co
Cobra Make, Engine: shell valley, 427ci 500hp
vic jr intake
I am using a vic jr. intake i believe and having to use a bigger scoop. engine just won't fit with that air cleaner and intake under the stock hood scoop. I even thought about lowering engine, but then I would not have much clearance.
09-12-2008, 06:56 AM
Il
Cobra Make, Engine: LA Exotic
I have an LAE(forerunner of B&B). It had a 351w with vic jr, 600 holly,3/8 spacer and the larger oval Cobra air cleaner. We added a 1/2" spacer between carb and air cleaner and still had plenty of clearance on the hood. I switched engines with a Wiend Stealth intake and 650 dp holley and phoenolic spacer...no clearance! Went with a 9" x 2" K&N filter and have the clearance needed.
I still have the oval Cobra if you are interested.
09-12-2008, 09:03 AM
NY
I'll let you know about oval cobra after I get everything together. Thanks...
Mike
