Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > B & B Cobra's --- Speak with Bryan Anderson
December 2024
Old 03-19-2009, 07:25 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default Anyone use Ceramic inserts or other sound limiter in the B&B pipes
I must be getting old. Looking to quiet it down just a tad.
Old 03-19-2009, 09:22 PM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Default sound
like to here what happens.he he. no pun.my pipes are rattling at some rpms and i need a solution that is a little more ,well quiet too.
the older i get the faster i was.
Old 03-20-2009, 06:14 AM
Clois Harlan's Avatar
After 8 years of being thrashed and having 110 octane pushed thru them I finally had Bryan make me some new pipes last year. At the time he told me there were different inserts you could put inside your mufflers to quieten them down. I am sure those things are still available.
Clois
"Let's roll"
"Be part of Something Good
Old 03-24-2009, 02:50 PM
BeasleyRB's Avatar
Cobra Make, Engine: B & B , 351W 400+
My pipes started rattling and I discovered some small tack welds had broken toward the rear of the side pipe. I looked up inside the outlet with a flash light and noticed them. I welded the insert back with some 3/32 6011 weld rod. The rattle stopped. It is rattle free at least for now.
Old 03-28-2009, 06:36 AM
jams's Avatar
Summit sells some cone inserts that "bolt in" I have never used them but someone on the forum recommended them to me in the past.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
