February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 04-04-2014, 03:15 PM
mln385's Avatar
Cobra Make, Engine: BDR
If you pull your plugs they should tell you as well.
  #22 (permalink)
Old 04-04-2014, 03:26 PM
Cobra Make, Engine: Backdraft 1048
Thanks All but at this point it's far above my skill level so I'm sending it off to the Seed Shop.
Gary
Backdraft 1048
  #23 (permalink)
Old 04-05-2014, 08:08 AM
I was doing a little research and came across several threads that say Felpro Gaskets are a weak point on Intake manifolds. My engine has them so is it possible my problem could be an intake coolant leak? If so how can i distinguish it from a head gasket coolant leak?
Gary
Backdraft 1048
  #24 (permalink)
Old 04-05-2014, 09:32 AM
Sideways's Avatar
This is what you need to know, article by Rick Lake
Before ripping the motor apart how about we do a couple of easy tests. Coolant pressure test to see if the system is holding. If not, looking at intake gasket and not having to pull heads off motor. Compression test and a leak down test will tell us alot about what is happened to the motor. I would also go with intake gaskets. Is there a milk shake look of the oil to start. Is the dipstick reading over filled with oil? Oil cap have a light brown or water on it? Just pull the valve covers and lets see what we have first. If there is some brown looking cream on the valve covers we have a coolant oil interaction. Might be just the intake gaskets or could be the head gaskets. This is the reason for compression and leak down tests. You want to compression number to be within 5-7% of low to high numbers. Leak down test you want to have about the same of 5-8% in all cylinders. If these numbers come out good, it's not likely to be a gasket for the head. Also at this point check all head bolts or studs for good torque reading. If everything checks out to this point, pull the intake. You said you are on the 2nd or 3rd intake gasket?? If so we need to look at the angles where the heads meet the manifold and where the bottom of the intake meets the block and check the angles. If anything was machined pass .005-.010" the angles could be too far off for proper sealing of this gasket after enough heat cycles. The other thing is how you install the gasket and what extra things are you doing. Heres a short list of what I do and have gotten 7 and now 8 years out of Fel-pro gaskets
Clean both surfaces, you know this. Check the angles with the intake dry on the heads and block do a light bolt down with 5-10 pound of torque on the bolts or nuts. Get a feeler gauge and you want less that .003-.005" to slide between the mating surfaces. This is for intake to heads only. If this is in spec, install gauges. If number is higher, how much? If you have over .010" This could be a sealing problem. If numbers are in spec, Get gaskets and spray 2 lite coats of Hi-TAC on both side of gaskets and let dry. Add a thin coat of GREY sealer to both top and bottom of gaskets and give it 3 minutes to skin. At this time put a nice bead on the motor block where the intake is going to rest. Install the intake gasket and make sure it's centered on all the ports and bolt holes. I know you are strong but need a 2nd person to install intake manifold to get an even drop down. Make sure the gasket don't slide down. Some guys use studs on one side of the motor to prevent this. Torque bolts or nuts in pattern from center out in 5-10ft pound incroments untill reach 30-35 torque reading. This sealer needs 24 hours before added fluids or running motor. This step is over looked many times and this can cause gasket failures. I use a Felpro 1247 gasket and got 7 years out of it and then rebuilt my motor to a 482 stroker that now has 8 years on it. The block, heads, and intake are all aluminum. The expansion rate is the same but more that an iron block, heads, and intake. Good luck, hoping it's the intake. Rick L.
  #25 (permalink)
Old 04-07-2014, 05:56 AM
I manage to check the coolant and there was no oil in the expansion tank and no coolant in the oil as far as I can tell from looking at the dip stick for level and foaming.
Gary
Backdraft 1048
  #26 (permalink)
Old 04-23-2014, 01:15 PM
Just to follow up the problem ended up being the intake gasket caused by the intake bolts not being the correct length they were to short. The car should be fully operational by Friday.
Gary
Backdraft 1048
  #27 (permalink)
Old 04-26-2014, 07:54 AM
Default Follow up intake gasket leak
The intake gasket fix solved the following problems.
1) White smoke out of passenger exhaust
2) Popping in exhaust at steady state RPM and when down shifting
3) All Bog when punching it is gone
4) Idle set to 850 previously 1000 was the lowest it would go
5) Run on when shutting the engine off is now gone.
Gary
Backdraft 1048
  #28 (permalink)
Old 04-26-2014, 10:14 AM
Cobra Make, Engine: SPF#1867 , KC427
Hope your issues are/get resolved. Did you buy they car from an individual or from a BDR dealer as a used car? I'm currently looking for cars and I've come to the conclusion it's in my best interest to pay a few thousand more for a car that is vetted by a BDR dealer. I've been down the try to save a dollar road and it always end up costing more in the long run. I used to be willing to dive into working on a car/bike but I just prefer to turn the key and go these days. Enjoy the car......I haven't had the opportunity to see a BDR car in person yet but I hear very positive things about them
  #29 (permalink)
Old 04-26-2014, 04:27 PM
I purchased the car from an owner but my thought was it was a roiling chassis built by backdraft and the had Speen Faninix install an engine built by D & D (I did get it for a really good price). I thought I would get a well engineered end product and since the car had only 4k miles that was a good assumption. If the owner built and installed the engine I could see issues but not from a professional organization. I don't know who is to blame for using manifold bolts that were catching by a thread or two but the problem is behind me know. I took her out for a spirited 50 mile drive today and all was well. I even got the wife out who was skeptical that it was too loud and smelt like gas and she loved it.
Gary
Backdraft 1048
