November 2024
Old 12-28-2014, 01:02 PM
Default Wont Crank
As I have posted in the past I recently purchased a wrecked Backdraft car a while back. I just started the disablemly process but want to hear the run before dis Assembly. I have power `12 volts and so forth but nothing. Jay at Vintage said the car had ran after the wreck so just wondering if there is some kill switch or something like that. It is a 5.0 coyote. Also where is the fuse panel on this thing?? Thanks
Old 12-28-2014, 01:29 PM
Cobra Make, Engine: Backdraft
You should have a battery red key that fits I into the battery cut off switch located under the dash on the transmission hump. There may be a small round black plastic cap on the fitting
where the key is inserted. Fuses should be on the passenger side. Pull the velcro attached
carpet panel off that is below the dash along the right side where your feet go.
Old 12-28-2014, 08:04 PM
Thanks a lot! But the only key I have is for the ignition.
Old 12-28-2014, 08:33 PM
Dwight's Avatar
Smile
the key he is talking about it a big red plastic thing for a shut off switch. It should be in the shut off switch. Look in the trunk for the battery and switch. Follow the battery cables from the battery to where ever they go. Some people put the shut off switch on the ground wire.
It may have an inertia switch that tripped when it was load onto a tow truck.
Dwight
Economy Battery Disconnect Switch - Speedway Motors, America's Oldest Speed Shop
Old 12-28-2014, 09:27 PM
Cashburn's Avatar
Backdraft Racing Dealer
Send me an email, pretty sure I know what it is. Btw your cutoff switch is in the trunk, it was customer ordered that way.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 12-29-2014, 07:09 PM
Will do Jay. Thanks
Old 12-30-2014, 05:30 AM
BDR0572's Avatar
Cobra Make, Engine: BDR, Roush 402R
I am new but on some models the transmission has to be in neutral ,even with the clutch applied it wont crank over if it is not in neutral.
Old 01-01-2015, 12:07 PM
OK got it to start just wont stay running. Battery has low voltage so I am charging battery now. Brian at vintage had told the wire to the ecm was disconnected from key. So one problem down.
