February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 06-10-2015, 09:05 AM
Default Hood shock
First and foremost, thanks for all the help on my other thread regarding my issues with the clutch... In order to avoid changing subjects there, I would like to ask if anyone know which "shock" is used for the hood on the BDR's... Mine is not working anymore and won't keep the hood opened
Does anyone know where I can buy a replacement one?
Thanks!
SS
Old 06-11-2015, 07:59 AM
6t8stang's Avatar
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
Most I've seen have a prop rod instead of a shock. Curious to see a pic of your setup!
Eric
Old 06-11-2015, 12:10 PM
I will take pictures of it this weekend and post them... I also want to post some pictures of the car itself... I guess I should have introduce myself before just asking newbie questions
Old 06-18-2015, 02:50 PM
MJC MJC is offline
Cobra Make, Engine: Backdraft RT3GT, Arancio Argos/Black Magic, Coyote XS, T-56 Magnum
My car is brand new and it just has the prop rod. The coyote motor was a tough fit with the rod I hear. I was told they made it work, although it is tight to snake it around the valvecover.
Old 06-18-2015, 06:18 PM
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
I had a good experience recently with this company.
High Quality Automotive | Marine | Industrial Lift Supports
When I said I wanted to be somebody, I probably should have been more specific...
Old 06-19-2015, 10:58 AM
the early cars had the shock, I have #98 and it has one. I was told to remove it and take it to AutoZone, etc. and they could match it. I also have heard they were never very good and the hood would slam when the wind blows.
Being a good KY hillbilly, I found that a small twist adjustable curtain rod works great as a prop rod. The have rubber feet on each end, and can be adjusted to use where you want under the hood. Also available in multiple finishes.
Old 07-13-2018, 08:21 AM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
I found a replacement hood shock that's an exact fit. I got it at Advance Auto and it is stock number E 4048. About $20 bucks with tax and its pretty strong. It would have to be more than a mild wind to blow hood over. Not too bad, I got almost 15 years out of mine which I know is not the norm.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 07-13-2018, 06:47 PM
Good find.
It took me a while to get the right fitment for mine and had to mailorder a few.
hood strut
Old 07-14-2018, 12:28 PM
Do you have pictures of yours! I would like to put a pair of shocks on my hood and need some information, how it would look. Some sizes would be great!
Thanks!
