January 2025
26 27 28 29 30 31
Old 07-15-2015, 07:51 AM
Cobra Make, Engine: Backdraft #832
Default Rosehill Performance Slave Cylinder
Has anyone installed the Rosehill push type slave cylinder on the ford 351/427 with the Tremec 500 or 600 tranny? If so how does it work for you. Any leaking problems?
Old 07-15-2015, 10:02 AM
I've used them quite often.....really nice pieces.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 07-15-2015, 10:20 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
jimbo01,
You also might want to try Mike Fortes at Fortes Parts Connection.
He sells a kit with a bracket that uses the CNC push slave.
Don't know if the kit you were looking at uses the CNC, but I'd recommend it over a generic one.
rodneym
Old 07-15-2015, 10:32 AM
Good thing about the Rosehill piece is that you can find the slave in any auto parts store.
Old 07-15-2015, 11:29 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
...good thing, too.
The CNC is a well made little unit. Sure it costs more ($65 vs ~$20) but I don't like to skimp.
I'm sure Brent would agree on that.
rodneym
Old 07-20-2015, 01:34 PM
After several conversations with Forte Parts Connection I found they produce a 7/8" and 1" CNC slave cylinder. The master cylinder that will fit the Backdraft cars using the Girling mount from Wilwood that are close to these sizes are 3/4" and 13/16" bore. I have not found a CNC slave that match the master cylinder. I understand the bore size of the master is to be the same for the slave.
