February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 08-02-2019, 09:36 AM
Cobra Make, Engine: BDR, 302
Default Ignition Switch
I lost one of my ignition keys and the locksmith said they couldn’t duplicate my old one. Any tips on getting the old ignition switch out. I thought I could turn the collar but the whole switch rotated and I’m afraid that I will tear the vinyl dash. I didn’t feel a collar nut on the in side. It is an old style switch.
Thanks.
Old 08-02-2019, 10:42 AM
Danr55's Avatar
2 little electrical screwdrivers should turn the front part of the switch really well. Just be very careful with them and you won't tear the dash.
Dan in Arizona
CCX3209
Old 08-02-2019, 11:16 AM
Phx Mike's Avatar
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
You need to get an “ignition ring nut removal tool” - it has fingers that will align to those slots on the collar of your switch so that you can keep the whole switch from rotating while you unscrew it from the back. I saw some online but they come in different diameters and with different number of fingers.
When you replace it consider getting one that just has a knurled collar that you can hold with your fingers or soft jawed pliers.
Mike
Old 08-02-2019, 11:30 AM
Cobra Make, Engine: Factory Five Mk4, Ford Racing Z427
Default Snap ring pliers should work
Something like this.
Old 08-03-2019, 04:50 PM
I ordered a tool on line that should hold the collar. But I tried a small pair of pliers (I know-too impatience—but I used a microfiber towel to avoid scratches). But I still couldn’t turn the switch from the behind the dash to loosen it. I’m pretty much stumped. Any suggestions short of drilling it out which I hope to avoid.
Maybe Jay knows some tips for an early BDR. Thanks.
Old 08-04-2019, 08:56 AM
Sailfish's Avatar
Cobra Make, Engine: Superformance #2144 with a Roush 342R (sold June 2018, but still lurking on Club Cobra)
I ran into a situation that dictated the need for a new ignition switch key. I was reluctant to change out the entire switch so I "Googled" the switch and key codes to find either a complete key or a blank. Couldn't find the complete key but did locate a blank. Paid approx. $7.00 for the blank and had a local locksmith make a new key. Just a thought.
Old 08-08-2019, 03:15 PM
I just got the four finger tool from Classic Industries and it fits and worked. I got the ignition switch out with no damage to the dash. Amazing what a proper tool can do.
The old switch has four connectors but with only 2 wires going to it. There are no markings on the switch or on the wires (1 wire has a white label but no writing on it). The new switch also has 4 connectors: battery; ignition; acc; and ST.
I’m guessing the wire with the white tag is from the battery and the other wire goes to the ignition. Any suggestions other than trying it? I don’t want to burn something out. Sorry to sound electrically challenged. Thanks.
Well the white wire was to the ignition and the unlabeled wire was to the battery. Cranked right up. The new switch is bigger around and a tight fit. But now I have the extra key.
