February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 03-13-2020, 06:20 PM
LudicrousSpeed's Avatar
Cobra Make, Engine: ...
Question Chin Spoiler ground clearance?
Just curious, I like the look and from what I understand it does have a positive effect on handling. Anybody know the ground clearance and if it causes major scraping issues?
Note: I accidentally posted this in the B&B section also because I have fumble fingers.
- Just call me Speed
Old 03-13-2020, 08:57 PM
t walgamuth's Avatar
My front is at 3". I am planning to raise it at least a half inch...or an inch.
Old 06-29-2020, 10:10 PM
SBSerpent's Avatar
Cobra Make, Engine: BDR build #983, FRM 392
How? Adjusting the front coilovers?
Old 06-30-2020, 05:15 AM
Yes. Once you get the car off its tires, if it has the coilovers, adjusting them takes five minutes per wheel or so. As a rule of thumb raising the shock a quarter of an inch should raise the car twice more or less as much due to the leverage.
Old 06-30-2020, 07:26 AM
FredG's Avatar
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
I don't think you will ever get it significantly higher for peace of mind. I covered the underneath with a spray rubberized coating to protect it from scraping.
Old 06-30-2020, 10:32 AM
SBSerpent's Avatar
The oil pan also presents a problem. I've seen skid plates attached to the underside of the pan.
Old 06-30-2020, 01:43 PM
My oil pan is above the cross-member where it is darned near impossible to hit anything with it.
