Fuel Tank Problems
http://www.clubcobra.com/forums/backdraft-racing/46668-fuel-tank-problems.html)
Blittleton |
10-27-2003 03:15 PM |
Fuel Tank Problems
I recently purchased #81 and having a little trouble with adding fuel to the tank. It seems to fill up quickly, then goes down after awhile. All I seem to get into the tank is about 5 gal before this happens. Anyone else having this problem?
I don't know anything about BDR's but if it has a fuel cell check to make sure the checkball in the vent is working properly. Sounds like it might be stuck closed.
CSCHWER |
11-03-2003 03:31 PM |
Shorten your vent hose about 9.5 inches. Mine did the same thing until i shortened the hose. The vent hose fills with fuel and acts like a trap.
George Snyder |
11-08-2003 04:10 PM |
Thanks CSCWHER,
I have the same problem with mine. I have an older model that I believe has the tank vent at a different location. I will shorten it and see if that helps.
Bud
Blittleton |
11-10-2003 03:12 PM |
Fuel Tank Problems
Thank you CSCHWER. My fuel tank problems are solved. Thanks again.
CSCHWER |
11-10-2003 04:22 PM |
Your very welcome, Backdraft is aware of the problem and it will be fixed on the production line. They seem very responsive to inquires.
Chet
Boudy |
11-12-2003 11:44 AM |
We try.
Boudy
chuckmynatt |
11-15-2003 08:01 PM |
Me too! Same problem. Fixed it too!
Chuck
