January 2025
26 27 28 29 30 31
Old 03-22-2004, 08:24 AM
Cobra75's Avatar
Cobra Make, Engine: CSX 4100-Shelby 75th Anniversary Edition
Send a message via AIM to Cobra75
Default Fan Indicator Light
Is the yellow indicator lamp supposed to light all the time the fans are running, or just when the fan switch is turned on?
Seems like it should be the latter.
Scott Harrison
CSX4100
Growing old is mandatory...growing up is optional.
Old 03-22-2004, 05:03 PM
Cobra Make, Engine: SPF 2682, Roush 427
Just when the fans are turned on manually
Old 03-22-2004, 10:51 PM
Cobra75's Avatar
That's what I would have thought, but it is lit whenever the fans are running even with the manual switch off. I wonder if there is a way to wire it differently?
Scott Harrison
CSX4100
Old 03-23-2004, 12:54 AM
Doug I's Avatar
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
The 1 I just drove had the light on all the time. It was Boudy's demo. Couldn't tell if the fans were on all the time or manually, they were off when the key was off and with 400 horses waiting you couldn't hear much else.
Then again ...... there I was with the key on and no fire ... check the key was all the way to the right ....... and ahhh harrr push button to start ...... not that one thou .... that was the horn which we now know works .... the little one hiding above the key.
We have fire ...... we had fire ...... make note to self to turn on the fuel pump. Now we have fire and it stays lit.
He still wants me to learn this left hand drive stick (I've driven 20 years right hand drive) on the track ......... ooookkkkk. It was a blast - and not nearly as hard as I was expecting.
Pull a gear .... drop the hammer .... and enjoy the Drive !!
Old 03-23-2004, 05:06 AM
I suspect track cars would be wired to have the light on when the cooling fans are on. On the street I don't see a need for this. If you want, I'll trace the wires to the light and email you the colors and where they go. Should be simple to correct. I've asked BDR for a wiring diagram, but all they seem to be able to produce is an installation wiring schematic.
Let me know. Work today, available this PM
Chet
Old 03-23-2004, 06:14 AM
Cobra Make, Engine: Midstates, Genesis 427 S/O
Post
Cobra75,
There are some other ways to wire them. When would you like them to be on? Let me know what you want and I'll show you how to wire it appropriately.
slithering
"God saved you by His grace when you believed. And you can't take credit for this; it is a gift from God".
Ephesians 2:8
Old 03-23-2004, 08:47 AM
Cobra75's Avatar
Originally posted by CSCHWER
.... If you want, I'll trace the wires to the light and email you the colors and where they go. Should be simple to correct. I've asked BDR for a wiring diagram, but all they seem to be able to produce is an installation wiring schematic.
Chet
Great, email is schhfh@cox.net. I too would love to have the complete BDR wiring diagram.
Originally posted by slithering
Cobra75,
slithering
Terrific...I think the light should be on only when the manual switch is energized. The fan's automatically come on with the thermostat when the ignition is on...that's great. But I don't think one needs to have that yellow light glaring you in the face to tell you the obvious especially at night.
Guys, Thanks for your help.
Scott Harrison
CSX4100
Old 03-23-2004, 03:30 PM
RallySnake's Avatar
Scott,
I have tried various ways of connecting the fan light on my Arntz. I believe that the way you have it is the best. Those electric fans and thermal switches are not all that reliable. Sometimes a fuse blows or a relay sticks and the temperature will keep climbing until, BOOM! It's much better to KNOW that the fan is on if the temperature is high. I located my light at the far right of my dash and it's green. When I'm creeping in traffic, I keep an eye on the water temp. If it gets over 200, that fan better be on. There have been times, though, that it's not. Then you have to hit the manual switch. That little light saved me some expensive repairs.
I think next time I open the dash, I'll install a two color LED. It will glow green if the thermal switch turns the fan on and yellow if it's turned on by the switch. That will help me remember to turn it off after the traffic picks up.
Paul
Old 03-23-2004, 04:49 PM
Paul,
My solution to the gauge monitoring was to install a Autometer Tri-Alert for about $70. It monitors a set point on 3 different gauges and turns on my generator light if one of the readings gets above or below the set point.
Chet
Old 03-23-2004, 05:21 PM
RallySnake's Avatar
Chet,
Wow, that's neat! I don't suppose that it would work with Stewart Warner guages, though?
Paul
Old 03-23-2004, 07:04 PM
It works with VDO. I think it would work with any "short sweep" gauge.
Old 03-23-2004, 07:19 PM
Thomas Gayer's Avatar
Cobra Make, Engine: B&B 66 427W Roadster
i put a second auto meter voltmeter in the fan circuit
when this voltmeter is zero, i know the fan is not running
when it is 13 volts i know the fan is on
i did not want a light in my face (my ugly face)
if the engine runs hot , i have to figure the t stat went bad and switch to manual, if still no volts i know to kill the motor to find out what went wrong.
tom
SSSSSSSSSSSSS
Old 03-24-2004, 07:01 AM
Cobra75,
You just have to install an isolation relay. You energize the coil and it closes a normally- open set of contacts. Having said that, you can then energize the coil off the thermostat side, and bingo your lit only when the fans are running. I'll be glad to walk you through it. Send me an email.
Chris-
slithering
Ephesians 2:8
