January 2025
26 27 28 29 30 31
Old 01-12-2005, 11:49 AM
Cobra Make, Engine: Backdraft 302
Default self cancelling turn signal, hi beam assembly
Anyone having problems with this assembly on their BDR? I don't like it. The set screw that holds the assembly on the steering column won't stay tight so the whole thing rotates as I turn the wheel, or if I'm not extra gentle while putting on a turn signal. I'd like to replace it with 3 dash mounted switches of some kind. Any ideas? Anyone change it out for a different solution?
Old 01-12-2005, 12:03 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
new BDR,
I had to replace my turn signal switch {it would not activate the lights} but have had no trouble with it getting loose. Have you tried putting a drop of loctite on the threds of the screw then tighten it up?
David
Old 01-12-2005, 02:10 PM
Secret Squirrel's Avatar
Cobra Make, Engine: Backdraft Racing BDR144
NewBDR,
I had a problem with the self-cancelling part, but not with a loose assembly. I did notice a few items that may help you while I was working on my steering wheel and turnsignal assembly. My set screw tightens up enough to hold the turnsignal in place without spinning.
Make sure that the turnsignal assembly is far enough back toward the dash so the set screw grabs the steering column. Also that the assembly will clear the rear of the streering wheel.
As for the self-cancelling part, I had to add an R/C airplane wheel collar to the strike pin on the steering wheel and add a little grease to the turnsignal arm behind the snap ring so it would return to neutral. There is a pic in my gallery of the wheel collar.
If you ever have to take apart the turnsignal assembly be VERY CAREFUL. There is a large spring and some sensor tabs that need to be put back into place very carefully with a small screwdriver. Its kinda tricky.
If davidlee's suggestion doesn't work, then you might try re-tapping threads to the next size and install new set screw. The assembly is aluminum, so use the proper thread locker.
HTH
Wayne W.
Pewter with Steel Gray Stripes
Old 01-12-2005, 04:48 PM
uncltodd's Avatar
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
The turn signals are a cruel joke on BDR # 139.
Give me input or talk to my lawyer.
Yeah, it's that bad.
UT
Eagles soar- but weasels don't get sucked into jet engines.
Old 01-13-2005, 12:47 PM
Boudy's Avatar
Cobra Make, Engine: BDR #42, 425HP 347 - NASA TX, CMC #55 Mustang Road Racer - Legends 37' Chevy Coupe #43 Oval Racer - Honda CRF450R(I'm afraid to race it), 95' Black Lighting Daily Scooter
The turn signal is of VW origion and is a little tempermental. It could also be, and has been, called a cruel joke if not adjusted properly.
If not self cancelling properly, it must be taken apart and re-assembled correctly. What happens is that when it is assembled, the darn little pieces don't stay in place and it goes together wrong. It takes me multiple tries to get it done every time I've done it, but it is doable.
The set screw should and usually stays tight. I'd first place locktight on the threads. If for some unheavenly reason that doesn't work, I'd mark the end of the screw and tighten it up. This will subsequently leave a mark on the column. The take a small drill and make a dimple in the column. All in all, it shouldn't twist then even if it gets loose.
Boudy
Old 01-13-2005, 02:21 PM
I'll try all that but do you have any info on the wiring scheme, colors, etc. for each control in case I want to replace with switches?
-- Ray D
Old 01-13-2005, 06:22 PM
Boudy's Avatar
Hmmm... Talk to Reg before you try to change it out. However, I don't recommend it.
Boudy
Old 01-13-2005, 07:27 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
I have the exact same problem, the whole turn signal mount moves. I think that I have tightened it so much that there is now actually a groove in the column underneath the set screw. My set screw is on the top and close to the edge which makes it very hard to get to. (body is in the way) Not looking forward to taking it apart.
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 01-14-2005, 09:11 PM
Cobra Make, Engine: Backdraft #69, 351W, T5
Send a message via AIM to brainbugnj Send a message via Yahoo to brainbugnj
I have the same issue... I am going to email reg and see what I can do, I think @ this point I have actually stripped the set screw.... it sucks, I don't like it @ all... I would like to get a replacement and then I will drill a set dimple for it...
Boudy - have you had to replace one of these before, does it suck?
Steve
Old 01-19-2005, 10:03 AM
Boudy's Avatar
Replacing the unit is not a nightmare. Taking it apart to tinker with the self cancelling part is where it gets tricky. I have replaced a couple. They are old technology so it's not surprising to replace one here and there.
Boudy
Old 01-19-2005, 12:28 PM
Should I give Reg a call to get a replacement? or is there somewhere else I can grab one?
Old 01-20-2005, 07:46 AM
Boudy's Avatar
Yea, just call Reg. He'll either have one or tell you where to get one.
Boudy
