January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 03-08-2007, 11:09 PM
Originally Posted by pmfranke
136 on the passenger side of the car, inboard , about 15* angle,so the wires are lower than the sensor inside the collector,its tucked in between the frame and the collector. rocks from the front tire could hit it , i think i'll make a guard. i used the vent tube for a return into the plastic gas tank and welded a new vent tube to the metal filler spout. pic's will take a couple of days , if you really need some. Peter.
Don't worry about the pics. You have installed it exactly where I was figuring. thanks for the info. Brian
  #22 (permalink)
Old 03-08-2007, 11:17 PM
Originally Posted by Roar
looks like you are on the right track to finding a solution. a piece of advise before you buy the system. Ask what options you can buy for the system and then you will find out how complete the system really is. I bougt 3 "options" after I had installed mine having o wait 14 days for shipping to Norway every time. (this was the period with sunnny days. I do not know what is included in your kit but the Holley kit did have several options Summit just dident inform me.
The system I'm using comes as a complete kit, all but o2 sensor installed. But your right, Summit is not fourthcomming with parts that may be needed for the main parts your purchasing. I've been burned on that before by Summit.
