January 2025
26 27 28 29 30 31
Old 03-12-2007, 05:46 PM
Cobra Make, Engine: Sold Backdraft #488 Roush 427R
Default Knock off wheel tools
What size stainless wire should I use?
What size and type wire pliers should I get?
What size lead hammer?
Where should I purchase these Items?
Thank You
Peter
Old 03-12-2007, 05:52 PM
JBo JBo is offline
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Thank You
Peter
Peter, CSX & AK owners manual state:
wire..At least 18s.w.g. stainless
hammer that came with AK is 3#, csx has a 5#
pliers are : reasonable quality safety wire pliers expect 35 dollars
Harbor freight has some, quality can be issue, a good tool co is best
AK manual says 300 ft # torque on knock ons or center caps
Jim
Old 03-12-2007, 06:07 PM
Cashburn's Avatar
Backdraft Racing Dealer
Thanks for the reminder. I gotta add kits to our store...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 03-12-2007, 06:40 PM
jdog's Avatar
Cobra Make, Engine: Shelby CSX4795 (Sold)
Thumbs up Finish line
Look to your left, & click on the Finish line link. That's where I bought mine. They are very prompt with delivery.
jdog
"If you can't run with the BIG DOGS, stay under the porch!"
Old 03-12-2007, 06:54 PM
Thanks JBo and jdog for the info. Found the items on the finish line site.
Jay do you have a store?
Old 03-12-2007, 07:10 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Jay
Is that store you keep talking about up and running yet?
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 03-12-2007, 08:13 PM
Cashburn's Avatar
Originally Posted by Trueoo7
Jay
Yup. Check the backdraftboys forum for details tomorrow. I'm fixing a minor annoyance with the layout and then it's all up to you guys.
VINTAGE MOTORSPORTS
Old 03-13-2007, 10:51 PM
Gun Doc's Avatar
Cobra Make, Engine: BDR#499 351W with Webers
Peters44,
What determines safety wire size is the diameter of the hole it will pass through. The wire should fit the hole. Common safety wire sizes are: .020 .032 and .047. For Cobra knock offs I would think .032 would be the minimum and if .047 fits, it should be used. One other thing to keep in mind is to keep the safety as short as possible. In aviation applications, wire runs are usually kept to 6" or less between tie points. Also, a proper safety will have 6-12 twists per inch. It is important not to have the wire too tight (stressed), or too loose.
Gun Doc
Old 03-14-2007, 04:47 AM
JBo JBo is offline
Default safety wire
Gun Doc,
I think you reversed your logic. The hole size should be determined by the manufacturers recommended wire size for the application. JBo
Old 03-14-2007, 11:20 AM
Gun Doc's Avatar
JBo,
Actually most fasteners come with holes pre-drilled. Of course, the hole size is dependant on the application of the fastener. I am sure most, if not all knock offs would come pre-drilled, therefore I stand by my statement that the wire should fit the hole.
Gun Doc
