January 2025
26 27 28 29 30 31
Old 06-24-2007, 07:40 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default loosing front mount differential carrier bolt
looking for help...over the winter installed a 3.91 rear end, when removing the old 3.15 ratio found the 14mm allen bolt to be loose??? At installation of the new 3.91 torqued the 14mm allen to BMW manual spec's of 70 FT/LBS. 1000 miles later a slight banging sound...checked out the noise...the allen bolt is loose again??? From the factory, no washer or lock washer on the bolt? Does it need some thread lock stuff, other problems?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 06-24-2007, 08:10 PM
Blittleton's Avatar
CC Member / Sponsor
always use red locktite with rear suspension.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 06-24-2007, 08:21 PM
Cashburn's Avatar
Backdraft Racing Dealer
Red Loc-Tite.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 06-26-2007, 04:29 AM
tamanaco's Avatar
OK...If red loc-tite is used, can this bolt be removed without the need of a 500 ft/# impact wrench? IE, just hand tools
Old 06-26-2007, 09:22 AM
Gun Doc's Avatar
Cobra Make, Engine: BDR#499 351W with Webers
To remove fasteners secured with Loc-Tite it is best to first apply heat (with a heat gun) to melt the Loc-Tite. It is a common practice in my line of work.
Gun Doc
Old 06-26-2007, 07:40 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Liek Gun Doc said but I use a torch- it makes me feel better
Old 06-26-2007, 08:44 PM
Cashburn's Avatar
Hey Doc,
They called today, said tomorrow late or early next day pickup... at long last. That thing will need a good wringing when you get it.
VINTAGE MOTORSPORTS
Old 06-27-2007, 06:24 AM
Gun Doc's Avatar
Jay,
Just in time for the Fourth of July!!!
Gun Doc
