December 2024
  #21 (permalink)
Old 07-06-2007, 10:04 PM
2KWIK4U's Avatar
Cobra Make, Engine: Lonestar LS427, Keith Craft 496 Genesis, 649 hp, 668 ft-lb, TKO-600, Dynatek Stack EFI
I knew the man's math skills were adequate, I just thought that he counted in increments of twentie$$ though. HeHe
Brad W.
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
  #22 (permalink)
Old 07-06-2007, 10:45 PM
Wink
Originally Posted by h2oman
80c = 176f
Conversion
0.555(degrees F - 32) = degrees C
1.8(degrees C + 32) = degrees F
This should be the correct formula.
The first equation is right.
The second one should read: (1.8 X degrees C) +32 = degrees F
e.g. 1.8 X 100C + 32 = 212 F
  #23 (permalink)
Old 07-07-2007, 01:23 AM
FST FOX's Avatar
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Brad W.
20's you must have me confused with someone else
I only went 2 or 3 times what else is a guy suppose to do when his car breaks
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
  #24 (permalink)
Old 07-07-2007, 06:50 AM
Cobra Make, Engine: BDR #212, 392 stroker
You are correct!
Obviously my math skills are not up to par.
I fixed it, thanks.
Ned
  #25 (permalink)
Old 07-07-2007, 11:55 PM
when I put my oil cooler in I also installed a oil temp guage. You might want to install an oil temp guage first to see what temp your oil is getting before you install an oil cooler. It's less time and money. Just a thought. Brian
  #26 (permalink)
Old 07-10-2007, 08:54 PM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Patrick, you don't need the cooler on that motor you have. The radiator is going to to your water system plenty cool enough that the oil will never get that hot.
By the way, the reason your oil temp is running around 50c is because you are measuring that temperature out of the pan. The blowby air is keeping it cooler because the oil gets stuck near the sender and gets cooled. Most likely the oil temp sensor is on a splitter with the oil pressure sensor. You would have to install it in the pan to get a better reading.
Best of luck, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
  #27 (permalink)
Old 07-10-2007, 10:27 PM
FST FOX's Avatar
Best of luck, James
great thanks, btw pm sent about the instructions also answer my other thread about the E-Brake, please
