December 2024
  #21 (permalink)
Old 05-16-2008, 12:09 PM
Sal Gerace's Avatar
Club Cobra Member
Cobra Make, Engine: CSX4300, C5AE-H, Toploader
Jimimac351 thanks for the tip! I ordered these gaskets and installed them. No more poping during shifts from exhaust leakes. My Cobra sounds great now! Thank You Thank You Thank You!
  #22 (permalink)
Old 05-16-2008, 01:04 PM
CobraEd's Avatar
I had similar problems initially, but then switched to "Mr Gasket" product which is asbestos sandwiched onto a very fine stainless steel wire mesh. Very strong. Here is the key though that could apply to most all gaskets, . . . I ground down the area on the gasket between the actual ports to be very thin. This way when you tighten the bolts, you are not trying to compress an entire foot and a half of gasket material. You are only compressing the material that actually surrounds the ports.
You can all thank me later
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
  #23 (permalink)
Old 05-16-2008, 02:36 PM
imagine2frolic's Avatar
Cobra Make, Engine: n/a
Send a message via Yahoo to imagine2frolic
I third the RTV COPPER SEALANT. Years ago when we use to do manifold, and header work all the time. We bought sheets of hi-temp gasket paper, and would ballpeen many of our own gaskets to an exact fit.
I have pinched a head gasket causing a coolant leak, and no start. I took it apart, and added copper sealant to the indentation, and the motor worked another 8 years that I know of, and it was a marine motor......GOOD STUFF
20mph is not fast, unless you are doing it in a 3/2, 1000sq. ft. house on 10 ft. waves!
  #24 (permalink)
Old 05-16-2008, 03:17 PM
BLUE427's Avatar
Cobra Make, Engine: SUPERFORMANCE ROUSH427 TRI POWER
(No more poping during shifts from exhaust leakes. My Cobra sounds great now! Thank You Thank You Thank You!)
SAL,
ARE THE AIR LEAKS IN THE HEADER SEALS WHAT CAUSES THE BACKFIRING, "POPPING" SOUND WHEN DOWN SHIFTING?
I ALSO HAVE THE CARBON DEPOSITS WHERE THE HEADER COLLECTS INTO THE SIDEPIPE. SOME OF THE BOLTS WERE LOOSE BUT I THINK I WILL NEED A GASKET TO SEAL THERE TO.COULD THIS BE THE CAUSE OF THE BACKFIRING? IT DIDNT DO IT WHEN IT WAS NEW. THANKS,
BLUE427
  #25 (permalink)
Old 05-16-2008, 05:41 PM
jmimac351's Avatar
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
SAL,
BLUE427
My experience has been that if the car is backfiring then you have an exhaust leak - either at the head or collector. If you found loose bolts then I'd bet that is your problem too. I sent Remflex a 4 into 4 gasket that fit the FFR header / sidepipes and they made them up in their material. Call and speak to Rem Jr.
  #26 (permalink)
Old 05-18-2008, 09:17 PM
BLUE427's Avatar
jmimac351 ,
THANKS FOR THE REPLY, I WILL LOOK INTO THAT
BLUE427
  #27 (permalink)
Old 05-18-2008, 11:41 PM
Sal Gerace's Avatar
Club Cobra Member
Blue427,
Yes I had a leak at the head. The exaust flange was slightly canted and it leaked where it met the head. The Rimflex is about an eith inch thick (about double any other gaskets) and it will fill a gap to about a 16th of an inch. As you tighten the gasket it will crush and fill the voids. No retorquing according to rimflex. Like jmimac351 said if your exhasut is popping then you have a leak.
