February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 05-30-2010, 10:44 PM
Default Oil Pressure
I have a stroked 351 W and need to know what the oil pressure should be at normal operating temps. With the oil temp @ 80 c and rpm at 2,000 the pressure is 26 psig. same at 3k and 4k.
Have 12 a/n lines running to cooler and using Brad Penn 20-50 oil.
Cold start up pressure @ 1,000rpm is 35 psig. Engine runs great but the pressure seems low ??
Glenn
Old 05-31-2010, 06:02 AM
That would require an answer that's based on a lot of different variables.
It would be easier if you told me what pressures you were seeing...
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 05-31-2010, 10:24 PM
Cobra Make, Engine: Factory five
If its zero and your temp is over 210 then I have bad news for you.
J
Jeffery E. Awender, D.C.
www.AwenderChiropractic.com
Factory Five Challenge Race Car
Old 06-01-2010, 12:49 AM
PANAVIA's Avatar
There are variable points, but my rule is ; at 180F , - No lower than 35 at 2000 rpm.
Steve
Old 06-01-2010, 03:15 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
I use Mobil I 15W-50 and hot on my 408W I have 25-30 PSI at 900 RPM idle and 55-60 PSI at 2000 RPM.....stock oil pump!!
Old 06-01-2010, 10:16 AM
Bob In Ct's Avatar
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Neutral
I've got a 351 Ford Motorsports engine, nothing special. I'm running Redline 5W-30 with a Moroso Racing filter (27 microns). 55 PSI at 2,000 RPM hot.
Bob
Old 06-01-2010, 01:59 PM
FUNFER2's Avatar
Originally Posted by drawender View Post
if its zero and your temp is over 210 then i have bad news for you.
J
:lol::lol::lol::lol::lol::lol:
Regards,
Kevin
Old 06-01-2010, 05:59 PM
DAVID GAGNARD's Avatar
Originally Posted by menace1 View Post
I have a stroked 351 W and need to know what the oil pressure should be at normal operating temps. Thanks,
Glenn
Anything bewteen 25 psi and 60 psi.........depending on engine rpms!!!!!!!!!!!!!!!!!!!!!!!
David
DAVID GAGNARD
Old 06-01-2010, 09:24 PM
csx wnab's Avatar
Cobra Make, Engine: superformance/427 fe ford
i go with what a guy named smokey yunick used to say about oil pressure. all that is needed is10 pounds for every 1000 rpm the engine is turning. so there.
1952 MG TD - 53 HP 1970 SS454 Chevelle - 900hp 2007 spo2669 - 485hp 2001 Spclconst. softtail - 114HP 2006 Roadglide - 88HP
sold Roadglide.....bought 09 XR 1200 - 90 hp stock
i would rather live one day as a lion, than one thousand days as a lamb.
Old 06-01-2010, 09:42 PM
Got the Bug's Avatar
Glenn
Glenn,
Congrats on the SPF! Great to have another titanium with black stripes in the South Bay.
Look forward to meeting you at an upcoming breakfast.
http://www.bayareacobraclub.com/localpage.html
Doug
Old 06-01-2010, 11:54 PM
Hi Doug
So your the reason all the old ladies and cops are snarling at me lol...
Looking forward to meeting you and others at a breakfast soon.
Glenn
Old 06-02-2010, 12:04 AM
Thanks for all your input guys, I bought a test oil pressure gauge and found that the pressure was normal. I'm calling Nisonger Monday and ordering a new oil gauge. Bigtime relief...
Glenn
Old 06-02-2010, 05:38 AM
Yes, but can you really trust a guy named Smokey????? You do know all racers lie, don't you!!!!!!!!!
At 80 c and running @ 2,000 rpm the pressure is 26 psig. same at 3k and 4k . Have remote oil filter and using 12 a/n lines to the cooler. Engine runs great but the pressure seems a little low to me ??
Yes, that does seem real low to me, 26 psi at idle would be my minimum, at 2000 rpms or better your oil pressure should be double that, regardless of oil lines/cooler...first thing you should do is check your gauge,then, I'd check with the engine builder and see what he says, ask about your bearing clearances also....
David
DAVID GAGNARD
