1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
04-21-2006, 10:56 AM
The ULTIMATE Chevy Cobra Engine
Ryan Falconer has these slightly used Chevy racing engines for sale. The specs are unbelievable, although they ought to be, because they are from the 2002 Indy Racing League season and have been converted for street use.
http://www.falconerengines.com
214 cubic inch/3.5 liter. Eaton 112 Supercharger, MOTEC FI, Dry Sump. 560 horsepower at 8,000 RPM on 91 Octane Pump Gas. 340 pounds dry weight. Bellhousing and Getrag 6 speed available.
These engines go to 10,000 RPM and originally cost upward of $130,000. I can't even imagine the noise these things would make in a Cobra.
04-21-2006, 11:30 AM
CA
would sound like a badss Vette
Hyde D. Baker
04-21-2006, 12:08 PM
Can do the same thing with a puffed alum SBF, probably cheaper.
04-21-2006, 01:27 PM
You can squeeze 560 horsepower out of a 214 cubic inch SBF at 10,000 RPM? Really? Wow.......
04-21-2006, 03:34 PM
Please re-read the quote..........."SBF", no mention of cu. in.
A blueprinted alloy stroker SBF (427) @ ~ 350# will easily attain 550+ reliable hp at lower rpms. Heck, that's even without a blower!!
http://www.keithcraft.com/ads/index.html#427SBF
04-21-2006, 05:40 PM
Beam Me Up Scottie
MA
For the asking price of $25K, I could buy some nice audio clips of the motor, buy a killer Ford engine and have money left over to light my Cuban cigars.
Warren
04-21-2006, 09:19 PM
Actually, the street version engine is $45k, and the first one is going into a Cobra.
04-22-2006, 07:33 AM
NJ
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Only problem is when you open the hood to show off the engine ,the distributor will be on the wron end!!
04-24-2006, 04:24 AM
LA
Cobra Make, Engine: Findling 001 - starting scratch build
Distributor??
I don't think that is a problem with the Falconer-modified IRL engine as it uses
a distributorless ignition.
....Fred
05-05-2006, 06:47 AM
Holy Hooters. When this thing hits the test track, somebody has to have a video camera running.
09-01-2007, 10:39 PM
IL
Cobra Make, Engine: Classic 427, I purchased it May 2005, the kit was bought in 1991. I'm not sure when it was completed! Installed GMPP Connect & Cruise 376/525 with T-56 S/M 3.55 gears about 2 years ago! 1/4 miles is with old setup!
For that kind I money I would just go ahead and get one of his V-12's and be done with it! And before someone says it, yes I know you could put a Ford V-10 in cheaper! And it would be,,,, well it would be cheaper!
Al
I want to do right, Just not right NOW!
09-01-2007, 11:16 PM
PA
For 45k... ANYWAYS!
What kind of power does it make at NORMAL driving RPM's?
Bagram AF Afghanistan
09-02-2007, 01:23 AM
Wi
Cobra Make, Engine: Arntz/SBC/Jag
none.
09-02-2007, 05:46 AM
CT
It's not about Ford or Chevy...it's just an awesome engine, but the original Illmore Chevy Indy car engine was based on the Cosworth F1 engine, badged as a Ford. Cosworth changed hands several times and whoever owned the company had access to all R&D. This engine would make for a killer lightweight Cobra for the track (and would sound incredible with 180 degree headers.
09-02-2007, 08:20 AM
Evryday is a roadstr day
Oh
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
I can never really figure this out....this section is titled, Bowtie Snakes....not to hard to follow, so why are guys still here ragging about Fords? Its a kit car, replica.....like Zoera-SC7XX said, its an awesome engine...enjoy it for what it is, or isn't. Lighten up...
aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment".... ...from Will Rogers
09-02-2007, 11:01 AM
Club Cobra Member
IL
Cobra Make, Engine: SPF #1507 427 Dart Block Windsor
Awesome engine, for sure, but a LOT of money to power a street car and probably not all that much fun to drive most of the time.
Maybe better in a modern-style street rod where you could see it.
JMO
Lowell
09-02-2007, 11:47 AM
PA
Calm down guys! i don't think it was trying to go in a FORD vs Chevy direction at all! I think people were just relating what they could buy for 45k!
Lowell hit it right on the head... Even though it was made into a "street" engine. It really is beyond the boundaries of a street car when it makes it's power at 8k. Remember, nascar engines have 800hp but are not at all built to drive on te street. there is a reason that they have to drop the clutch on takeoff... it's not to get out of there quick, it's to keep from stalling the car.
09-02-2007, 12:56 PM
IL
Don't be to hard on the Die-Hard Ford guys, they are like cheap hookers, kind of fun to have around. They get the snott beat out of them and the next day they are back for more and with a big silly smile!
Al
09-02-2007, 06:34 PM
Aren't those engines torn down after every use?
So, drive around, get home, dust off the car, pull the engine, rebuild, put engine back in.
Repeat.
Would that pretty much be the schedule?
Do they come with a 100,000 mile warranty? 50,000 miles? 10,000? 1 mile?
Sounds like the very definition of 'high maintenance' and 'over-stressed'.
09-02-2007, 07:09 PM
CT
That engine is much like the Corvette ZR1 from 1990-1995...a 4-cam injected Indy style V8 built by Mercury Marine for GM. It has held up well and many are running well with 100,000+ miles.
Chevrolet lost big bucks with every car sold.
