January 2025
26 27 28 29 30 31
  #21 (permalink)
Old 12-24-2010, 07:24 AM
Double Venom's Avatar
Wetdog,
As I expected, an IMMACULATE installation! The rest makes me cry , schuse me while I find a roll of tissues!
  #22 (permalink)
Old 12-24-2010, 09:36 AM
MaSnaka's Avatar
Your used motor sure has a problem. I think I like the new one though. Getting back to the coil on it's side, mine was mounted that way and lasted for years until I was told about it's prone to failure. I bought the black one that is solid and can be mounted on it's side or upsidedown for that matter. It is for high vibration environments, in a Cobra???Nahhh. Anyway if you shake your red one you can feel the oil in there. Now I have a spare (the red one) which I keep in the trunk.
John
  #23 (permalink)
Old 12-24-2010, 06:20 PM
Cobra Make, Engine: classic roadster,408cu
Default old coil
the red coil in the pic was the old one , it was replaced early on with an epoxy coil that inhabites a different location , I once had an oil filled coil act up and I had to stop every 3 miles and cool it off with water from the nearby swamp and an old tupperware i found ...good times WD
