March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
  #21 (permalink)
Old 09-18-2013, 11:53 AM
Double Venom's Avatar
MC:
Shipped 9-18-13 UPS # 1z4282350354040993
Confirm when it arrives please.
Found the other piece to the latch...put it in the same box at the same cost!
DV
  #22 (permalink)
Old 09-20-2013, 04:09 PM
Cobra Make, Engine: Classic, 347
DV,
Got 'em.
Thanks for the extra piece.
MC
  #23 (permalink)
Old 09-20-2013, 05:02 PM
All right then!
DV
  #24 (permalink)
Old 09-28-2013, 08:33 PM
Just when you think you've cleaned shop it's time to get into the attic!
Two DELCO gas shocks for a CR. Even have the bump stops installed already. NOS of course, need them? Pick them up for free or I'll ship UPS for $25.00. MII front end of course.
DV
  #25 (permalink)
Old 10-01-2013, 04:08 PM
Today's gift bag,
Just changed OEM lowers for a guy today to Heidts tubular coil overs. The old springs are stock OEM type for CR's, and are in excellent shape. The Ford MII lowers are greasy but they too are in excellent shape, no rust what so ever, newer "bolt" in ball joints, even has the boots.
Again, if you have a CR's Cobra, MX, or a Healey and you need this type package/parts stop in and they are yours. Or, I'll mail them out UPS, probably $40.00. (Got the shocks too-see a couple of posts up.)
DV
GONE
  #26 (permalink)
Old 10-02-2013, 09:03 AM
DV - What size spring do you use with the Heidt's setup?
I'm using 8" x 2.5" diameter 450 lb. mains with 2" tenders.
Jeff
  #27 (permalink)
Old 10-02-2013, 10:55 AM
Jeff,
I forgot what motor your running?? small blocks use around 350 lbs and smaller / Lighter.
Big blocks will go all the way to 425 / 550. Depending on if it's the aluminum Viper motor! A 460 EVEN with Alu. heads & Intake will normally run 400 +.
DV
