1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
08-17-2013, 08:00 AM
Mi
Free!! Well almost,,,
I set of REAR chrome Pro-Shocks for a CR Cobra or MX. (Still in "dirty" box). Never used. PART # PRO # 9901 GONE
CR's "stock" pedal box.
Aluminum special spacer studs for rear shocks. New but aged... GONE
Shipping $25.00
CR's rear coil MOUNTS-Will separate for $15.00 shipping.
Don't forget I have a brand new hub assembly for 11" up grade front brakes!
SPINDLES
BEARINGS
MASTER CYLINDER (napa reconditioned-new)
7" Corvette BOOSTER (NEW) (This is a huge up-grade to the M-II Booster)
SPINDLES
NEW:
BEARINGS
CALIBERS WITH BRAKE PADS!!
BRACKETS FOR THE ABOVE
11" ROTORS! NEVER USED
Everything here is a direct bolt in on an M-II brake system.
You DO need to get a small proportioning valve and GET RID OF THE M-II VALVE!
My thought is this IS the single biggest upgrade to the Cobra other than a side-pipe modification!
$500.00 and I will take care of the shipping cost.
DV 231-869-4608
08-18-2013, 06:29 PM
NY
Shocks
Hi... I am interested in the shocks and any hardware needed to mount them to my early 90's CR. Please let me know the total cost to 12065. PS: All the parts I have bought from you in the past have worked out great Thanks...Charlie
08-18-2013, 06:43 PM
NY
Hi Ed
I sent a private message
08-20-2013, 05:05 AM
Mi
HP,
That is the total costs! $25.00 for the shipping. any more than that and I'll cover it!
Per your PM you don't need the screw jack mounts. ( You have to have these since your car is built). It will include the spacers and both PRO shocks.
AND, I sincerely apologize for the extra work/costs you had to do on the carpet package I sent you!
DV
Send check to"
DV
4905 Wayne Rd.
Pentwater. Mi
08-20-2013, 05:13 AM
Mi
Misc parts
Still cleaning shelves:
Found a CR Hood latch BOX
also an unmodified (VW) latch for the above box.
(No pull cable)
$20.00 for shipping
DV
08-20-2013, 07:42 PM
NY
Hi Ed,
The check is in the mail. Thanks again Charlie
PS: The carpet turned out great!
08-25-2013, 07:50 AM
Mi
Charlie,
Got the check Sat.. Monday on UPS- Ill get you the tracking #.
Sorry no more Heater decals/controls.... But, I do have a new and assembled heater box! ???
Why anyone would want one is beyond me  ??? Ask and I'll be glad to tell you a different heater/defroster box that is a simple bolt in, no assembly and this one really does work well!
DV
08-25-2013, 08:17 AM
NY
heater
Hi Ed,
My dash is not installed yet. It has the cutout for the Mopar push buttons that I got from you some time ago. I struggled to find vacuum diaphragms that would adapt to the heater box. If you have something that is better and not too expensive I would like to know more. Ideally it would not need a lot of dash cutout mods. Please let me know. If easier, personal message me or I can call if that works better. Thanks again for your help....
08-25-2013, 11:40 AM
Mi
Fella I am referring to a "Vintage Air" heater defroster package. The biggest thing is you do NOT need to cut a 4" hole in the passenger side foot well for an intake system! Second it is much smaller than Cr's box and certainly easier to mount. I put them directly on the firewall in the middle of the dash area. Just remember to raise it up just high enough for the heater door to open and miss the floor. The rest is simply run the included hoses to the defroster ducts!
If I remember right they want +/- $250.00 for the complete package.
See Vintage Air on the web. Get their catalog- piece of cake!
DV
08-25-2013, 08:54 PM
NY
Thanks for the advice and the info. My CR heater is already mounted with the fan motor in place. I will have to study it a bit to decide if the tear out is going to buy me a big advantage. I took great effort to mount it with the vacuum diaphragms, water valve and vacuum reservoir. These after big decisions are a killer... Thanks again
08-26-2013, 07:36 AM
Mi
I know....But your passengers will really appreciate the extra foot room the vent Intake takes up! (It's also easy to change the round control knobs to rockers- matches CR-s better.
UPS #: 1Z42823550354112030
DV
08-29-2013, 11:07 AM
Mi
Charlie,
U.P.S. says they are delivering today.
DV
08-29-2013, 06:01 PM
NY
Yes they arrived today. Thank so much, they look great and will be put to good use. Let me know what other parts you might come across. Thanks again
08-30-2013, 07:19 PM
Mi
Cobra Make, Engine: Classic, 347
DV,
I'll take the hood latch and box if you still have 'em. Thanks for offering.
MC
08-31-2013, 03:56 PM
Mi
OK,
but NO striker, NO cable. Cable is a basic choke / throttle cable. Watsons, Speedway, VW all carry the striker.
Send me $15.00 for shipping and don't forget to put your return add. on the envelope please.
DV
09-16-2013, 09:29 AM
Mi
Did you ever get my check? Sent it out a few weeks ago. Thanks.
MC
09-17-2013, 01:45 PM
Mi
A few weeks ago!? Got it Sat. will be on UPS tomorrow!
09-17-2013, 02:30 PM
mi
Cobra Make, Engine: jcf slabside,302 ford
DV I am looking for some Jag splined hubs for a project I am working on, have anything around?
09-17-2013, 04:16 PM
Mi
Sounds like a neat project, but no, Sorry, not since 2003.
DV
09-17-2013, 04:55 PM
Ca.
Terry,
A friend of mine has a pumpkin (in rough shape) with the calipers and rotors. He also has the wishbones, axels and hubs if you are interested. Probably cost more to ship them from Ca then they are probably worth but he is only asking $100 + shipping for everything. PM me your e-mail address and I can send you pictures if you are interested.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
