-   -   Mickey Thompson sr sportsman tires for the front (http://www.clubcobra.com/forums/classic-roadsters-ii/133294-mickey-thompson-sr-sportsman-tires-front.html)
McCobra 05-21-2015 05:27 PM
Has anyone used these tires and if so did you buy the 8" or 10"
I run a 235 now (thank you Yokohama for stopping production on them...) which is a 9.6" tire.
The guy at Discount looked at my Classic and was afraid the 10" might rub on the fender
I hate to step down in width but the rub would be worse.
Thanks,
Mike
Shootnride 05-21-2015 07:06 PM
Mike,
I had the 10 x 26 SR's on the front of my SPF and they were fine.
Ted
McCobra 05-21-2015 07:14 PM
Thanks Ted,
How do you like the performance of the tires so far?
Shootnride 05-21-2015 07:57 PM
Mike,
I no longer have the SR's on my car, but not because I didn't like them. I had the 12 x 28's on the rear and was not able to get the ride height down to where I wanted it and the only other option with the SR's was to go with the 12 x 26 which was a little shorter than I wanted. There are several guys on this forum that use the 10 x26 in front and the 12 x 26 in the rear and seem to be quite pleased with them.
I now have the MT ST's on my car (255/60 front and 295/50 rear) which are working out fine, but I can tell you that they do not have the traction that the SR's had.
Ted
Lightingrod 07-31-2015 05:55 PM
Not mounted them up yet but this is what I got for the rear!
Mickey Thompson 3755R, Mickey Thompson ET Street Radial Drag Tires | Mickey Thompson
DWRAT 07-31-2015 06:56 PM
I love my SR's on my Superformance.
I have 26X10 in the front and 28X12 in the rear.
Great looking tires and grips very very well except in the water.
RET_COP 07-31-2015 07:21 PM
I had 8 on the front and 10 on the rear. I should have gone wider on both. The tires gripped real good. I thought the side walls were not as stiff as I would have liked. I had them on 15" wheels.
hinoonaz 07-31-2015 07:26 PM
I have the 26-10 in front and 26-12 in the rear on a factory five. Never a problem with wheel rub. I am set at 4 inchs. Plenty of traction. The fronts look newer than the rear !
