-   -   side pipes (http://www.clubcobra.com/forums/classic-roadsters-ii/135942-side-pipes.html)
gn_n_60_shelby 02-28-2016 09:28 AM
side pipes
I know this has probably been revisited a lot
I am looking for a supplier for side pipes to fit a classic roadsters body.
Bernica 02-28-2016 10:32 AM
You might try to work with these guys if they are still around. Not sure how much variation there is on your bodies and setups vs what is available off the shelf. You may end up building a prototype set of pipes that fit just right, then find someone willing to produce them as needed or find a used set that fit and use them as the guide for more fabrication.
Good luck with your project. Looks like fun!:cool:
Stainless Specialties
Wisconsin_Snake 02-28-2016 07:54 PM
The side pipes to the CR are unique because the CR body is longer than other Cobras. Like Bernica said, you are probably going to have to come up with the specs and get some one to produce them for you.
That said there should be plenty of members here that would be happy getting the specs. For the side pipes "Classic Chambered Exhaust" is the place to go.
wkooiman 02-28-2016 09:07 PM
Make 'em yourself
If you already have the headers and just need side pipes, it isn't very difficult to weld on new mufflers.
I recently did mufflers from Classic Chambered. They have mufflers designed for Cobras, and they even have the proper turnouts.
Their website shows a retrofit. Once you get them like you want, you can send them off to be coated.
