1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
4Likes
2
Post By moore_rb
Post By 1795
Post By Karl Bebout
04-10-2016, 09:23 AM
Cobra Make, Engine: All original, with Chevy engine since 1964
I re-did my car's side pipes... AGAIN.
When I bought my ClassicRoadsters, my online research about the car led me to this past thread about how restrictive the Stock CR sidepipes were, and so naturally, I had to cut mine up and replace the restrictive twin-tube mufflers with a set of glasspacks...
Classic Roadster exhaust dilemma
Well, after running the 30 inch glasspacks for several months, I decided on 3 things:
1) The 30 inch mufflers are too long. The CR already looks like a long car, due to the extra 4 inches of wheelbase. The longer mufflers simply accentuated that dimension. Plus, the 30 inch mufflers were still too mellow in the sound department, for my taste.
2) The factory CR turn-outs also have two downsides that don't suit my tastes- The downward angle on the CR turnouts is too severe (they look like the sidepipes that guys used to to put on their chevy vans in the 70's  ; and two: The 3 inch diameter of the turn outs are too small. Original 427 side pipes had 3.5 inch turnouts.
3) I decided I wanted black side pipes instead of silver.
So, I cut them apart (again) and re-did them (again)...
I ordered a set of 22-inch glasspacks (4 inch diameter, 3 inch core tube), a 3.5 inch U-bend (to cut the new turn outs from), and some header flanges from Summit racing, and welded these up. I set the turnout angle to 12 degrees. Then, a quick run to the local Lowe's for some Ultra hight temp barbeque paint, and voila...:
I think the shorter mufflers, and the larger diameter turnouts, both come together to make the side pipes look shorter overall on the car, and they help to adjust the viewer's eye to the CR's longer wheelbase. I'll take some full-car shots from the side later this afternoon...
Why did I add the quick disconnect flanges? Well, because I still had those leftover 3 inch CR turnouts and hanger brackets laying around.... I had to do SOMETHING with those, right?
So, I reset the outlet angle on them to 12 degrees, and blended them into a length of 3-inch straight pipe... So now, when I want to run 20 pounds lighter (and 20 decibels louder  ), it only takes me 5 minutes to swap the mufflers out for these wicked-loud, USRRC sounding bad-boys:
- Robert
04-10-2016, 10:31 AM
Side view comparison shots:
Before (with the 30 inch mufflers and original classicroadsters outlets, taken in Sept 2015):
After: With the 22 inch mufflers and larger outlets with shallower turnout angle (taken this morning):
- Robert
04-10-2016, 10:35 AM
NY
That looks much better. Nice job. I cannot imagine how loud that will be without the mufflers. The neighbors must love you when you fire it up that way
04-10-2016, 11:06 AM
Thanks  Fortunately, my 4 closest neighbors are all gearheads, too - I'm surrounded by lifted 4x4's, Harleys, and hot rods
With the 3 inch straight pipes bolted on, it idles at 80dB, and WOT's at 100+dB, and it sounds EXACTLY like the car in this video (Even makes the same suck-back sound when I shift gears  ):
https://youtu.be/s9y8a1_56HA
With the mufflers in place, it idles at 72dB, and WOT's at 95dB
Needless to say - It will be spending 99% of the time with the mufflers bolted on....
- Robert
04-10-2016, 02:10 PM
OH
Cobra Make, Engine: West Coast Cobra, SVO 460, Richmond 4+1
Very nice looking. I like the black much better.
Joey
Liberty Twp, OH
West Coast Cobra
Red W/ White Strips
SVO 460
Richmond 4+1
04-10-2016, 02:18 PM
NY
One last suggestion, paint those bolts black. They stand out too much and detract from your nice work.
04-10-2016, 07:25 PM
AZ
Robert,
Looks nice but no more heat shields???
They have saved my but a few times so far.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
04-10-2016, 08:24 PM
AZ
Great improvement Robert. I personally like lots of Dbs, but of course, I'm deaf in one ear and can't hear out of the other.
Karlos
04-10-2016, 08:51 PM
Ca
Cobra Make, Engine: 1965 Cobra made by Pacific Roadsters. 351 Windsor Crate Motor, 5 Speed Tremec Transmission
Nicely done, I prefer the black as well and good call on shortening the length.
I want to make my exhaust black as well. You said you used high temp BBQ paint from Lowes. My current pipes are ceramic coated silver, is it possible to paint over my pipes with a high temp paint?
04-10-2016, 10:07 PM
Thanks everyone -
Dan- Yeah, I'm going to go it without shields for awhile... Living dangerously.
1795- great idea on the black nuts - I'll be taking your suggestion.
Springbok - Yes, you can paint right over the ceramic coat- just give them a good sanding with 220-330 grit, followed by a good wipe-down with acetone, then the high-temp paint.
- Robert
05-26-2017, 12:13 PM
TX
I know this is an old thread and I think you have sold your car since any chance you could tell me what size flanges you purchase from Summit?
Thanks!
05-26-2017, 04:12 PM
Thanks!
I used these:
https://www.summitracing.com/parts/pte-h7260
- Robert
05-26-2017, 05:11 PM
Ne.
Check out mine in my photo's. I used to make a highly polished 304 stainless sidepipes in a kit form. No glasspack to wear out. Sounds deep.
Website-
http://www.fireflyperformance.com/pipekit/index.htm
Regards,
Kevin
05-27-2017, 07:08 AM
ca
Cobra Make, Engine: Classic, built in 1991 has a 351 Windsor single 4 bbl.
Ceramic coating
While you have the exhaust system apart consider having your headers and collectors ceramic coated. I was having a vapor lock problem and did several things to mediate the problem. The most impressive was ceramic coating. There are numerous colors to choose from. I chose chrome and it matches the mufflers. I measured the surface temp of the headers and muffler and there was a 125 degrees difference. The headers measure 180-190 and the mufflers measure 300-310.
05-28-2017, 12:12 AM
TX
Thanks!! Just ordered them. Will report back once everthing is completed. Super excited to feel and hear the results. Going with black too.
As for headers I had them wrapped in this space age stuff that does the job.
