January 2025
26 27 28 29 30 31
Old 10-17-2017, 09:22 PM
Cobra Make, Engine: Classic Roadster,302
Default Mounting Driving Lights
I have been considering mounting additional driving lights in front of the radiator in the opening. I was wondering if anyone had any suggestions/ideas on how to mount them and what brand lights would be recommended. Many thanks for all replies and advice. Doug
Old 10-18-2017, 07:41 AM
Cobra Make, Engine: FFR Challenge Car, RDI aluminum 427w
I'd switch to Hella 7" E-Code headlights first. I wouldn't have added driving lights if I'd done these first.
HL79562 Hella 7" Round H4 E-Code Headlamp, Each | Rally Lights
I built brackets that attached to the quick-jack mounts for the driving lights. This was a lot of work but looked great.
Jim
Old 10-18-2017, 09:49 AM
Cobra Make, Engine: FFR fat block tko 600 9"
Thanks for the info. The stock ff5 headlamps are pretty sucky...
If aliens are so smart, why do they always choose to talk to guys named Bubba?
Old 10-18-2017, 10:28 AM
It's not really FFR, it's US DOT sealed beam lights. Nobody likes them but they are cheap.
Note E-Codes are European spec, generally better than DOT. You'll need to order H4 bulbs as well. I'd get standard wattage and then work from there. Standard bulbs are not expensive, as you go up in performance the price goes up. Factory wiring may not be up to the capabilities of the higher wattage bulbs.
Jim
Old 10-18-2017, 02:56 PM
Texasdoc's Avatar
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
I got the E codes (Cibie 82440) and the Hella 100/80w bulbs. I upgraded my wiring to handle the load as well. No problems with visibility now. All from Amazon, all in $100.
Also, any of the Jeep LED upgrades will fit.
