February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree11Likes
  #41 (permalink)
Old 09-01-2021, 09:56 PM
Haven’t posted in a bit. Finished the brakes, clutch cable, steering, throttle cable and pedals. Took it for a spin around the yard in the “go cart” form. That was fun! I put the body on just to mock up the seats and roll bars and check fitment of everything else. Going to try to finish the roll bars tomorrow. They are just sitting in there now. They will need to come up a bit and be made to meet the frame behind the seats. I’ll post pics when they’re done.
  #42 (permalink)
Old 09-03-2021, 09:09 AM
You're making great progress! I'm watching your build closely. I'm going to start mine this winter.
What pedals did you use? I don't have the pedal box for a standard with my kit, so I'll have to use an aftermarket set or one from a donor. Not exactly sure what I'll do there, cable or hydraulic, floor mount, hung, reverse res...
What kind of clutch cable, throttle, master cyl?
  #43 (permalink)
Old 09-03-2021, 05:27 PM
Thanks! I am trying to keep it moving forward. I used the original pedal box. Actually I have an extra if you want it. I can send it to you. I don’t have extra pedals, but you are welcome to it to try. So I used the kit pedals. I went Mustang cable for the clutch. I had to modify the clutch pedal to accept the cable and added a cable adjuster. I used a Lokar throttle cable and linkage. I again had to modify the throttle Pedal rod to accept the cable. I got the master cylinder from Orielly’s. It’s for a 69 Corvette. Part number NMC11410. It’s a disc/disc master. I can take some pics of the pedal assembly if you’d like me to.
Sycraft likes this.
  #44 (permalink)
Old 09-05-2021, 05:21 AM
Cobra Make, Engine: Classic Roadsters, Ford coyote Gen1
AC Cobra FB page, I've seen headers and side pipes for sale recently for $450. With a little fab work, they should fit your CR. Your set up will leave your huevos poached on a long run.
I might still have my CR bumperettes somewhere, since I had a set of quick jacks made for my CR.
Mark
  #45 (permalink)
Old 09-05-2021, 05:33 AM
Mark
  #46 (permalink)
Old 09-05-2021, 06:47 AM
Originally Posted by markantioch View Post
Hi Mark. I’d definitely be interested in the bumperetts! On the side pipes, if they aren’t off a CR, wouldn’t they be too short and end up exiting too far forward? I actually tried to find pics of a CR with the shorter pipes to see how it looked and didn’t see any. I am learning as I go for sure and thank you for your input!
  #47 (permalink)
Old 09-05-2021, 02:54 PM
If you can weld, or know of a good welder, cut and add a small section to the muffler/baffle tube. The $450 is about half price of a new set. I've also seen other sets for sale on that FB site.
I'll look trough my parts for the bumperettes.
Mark
  #48 (permalink)
Old 09-08-2021, 06:25 PM
I would defiantly love to see some pics. The pedal box, if a standard, might be useful in figuring out my set up. I'm going to pull a set from a foxbody too. I think I'm going to run a cable system and upgrade the clutch quadrant and throw out while I'm at it. I'm going to run a single piston gm caliper in the front, and SN95 disc brakes in the rear. I'll PM ya with my info
  #49 (permalink)
Old 09-11-2021, 04:37 PM
https://scontent-hou1-1.xx.fbcdn.net...2d&oe=6163E2B1
Fabbing headers out of stainless for the Coyote engine.
Next is getting rid of the 20 plus year old suspension for some Heidts tubular A arms.
74proii likes this.
Mark
  #50 (permalink)
Old 09-12-2021, 06:33 AM
Very nice!
  #51 (permalink)
Old 09-12-2021, 07:11 AM
sunman's Avatar
Perfect on the arms. They will go great with your Heidts 58” IRS
With 74ProII and eaks there are 6 CR builds/ rebuilds happening. That’s a lot
Anybody have sway bar diameters you can post?
Party On
Chaney Shores Studio
  #52 (permalink)
Old 09-14-2021, 07:56 AM
OOOOOHHHHHH, another Coyote. Interesting you went with the Mustang mounts vice the F150 ones. I would be very interested in those header dimensions, as I will not to do so as well. Any more pics? Yes I noticed your Alt mount set up.
markantioch likes this.
  #53 (permalink)
Old 09-18-2021, 07:47 AM
The frame had to be modified some to allow the hood lid to close all the way. The coyote is all heads, so the mounting points had to be lowered just a little. The alt is from a tractor, and it had to be reversed mounted since it's original location was down below. Also, that let me keep the original belt configuration.
I had to refab the drivers side header, since it was made a few inches to long, and the pipe placement angle was wrong. Just part of the long list of of things the builder screwed up.
Fabbing the headers all depends on your engine placement on the chassis.
https://scontent-hou1-1.xx.fbcdn.net...74&oe=616AB3A8
Mark
  #54 (permalink)
Old 09-18-2021, 07:51 AM
Mark
  #55 (permalink)
Old 09-18-2021, 12:59 PM
https://scontent-hou1-1.xx.fbcdn.net...b7&oe=616D5B0D
The coyote motor will need to be shoed in on an angle to allow the steering rods, and links to get past the headers on the passenger side.
Stick with the Oval Blues ECM. My builder went with Holley...I hate it, nothing but an expensive over priced pain in the ass, prostate deep.
https://scontent-hou1-1.xx.fbcdn.net...33&oe=616CB776
Here you can see the room needed where the alternator use to be. The steering rack had to be moved over about an inch and a half to get it to line up.
If I had a do over, I'd go the 363 strocker route with 550 to 580hp. More than enough for this feather weight car.
Mark
  #56 (permalink)
Old 09-18-2021, 01:48 PM
You can see clearly how much longer the drivers side header is compared to the passenger side, do to shoeing the motor in at an angle to clear the steering rods.
74proii likes this.
Mark
  #57 (permalink)
Old 09-18-2021, 03:27 PM
Originally Posted by CFD2DC View Post
Roylerumble I’m missing small things like headlight assemblies, turn signals, bumperetts, brake/tail lights, steering column and trunk latch mechanism. The big pieces missing are windshield assembly, headers and side pipes. I have the complete interior, all body panels and pieces and all the frame/chassis pieces.
Jeff
Try them for side pipes. If you still want to go that route.
https://www.ultimateclassiccars.com/
I found the bumperettes.
The trunk handle, I've no clue where that went. I didn't use it, went with a clean shaved look.
https://scontent-hou1-1.xx.fbcdn.net...66&oe=614C5810
https://scontent-hou1-1.xx.fbcdn.net...82&oe=614B5C78
Mark
  #58 (permalink)
Old 09-18-2021, 08:39 PM
[quote=markantioch;1497236]Try them for side pipes. If you still want to go that route.
Mark. Thanks! I sent you a PM about the bumperetts. On the trunk, I just fabbed a mount to use an original style handle mechanism. On the pipes, I think I’m going to stay with the under car for now. If it doesn’t work out, I can always change it.
  #59 (permalink)
Old 09-19-2021, 12:56 AM
I knew it would be similar length wise . I may go the "j pipe" method. Thanks for the pics. I already have Mustang mounts, was planning on modifying F150 mounts. The alt relocation is very similar to the "Power by the Hour" unit. That pic makes it look the radiator looks notched.
  #60 (permalink)
Old 09-19-2021, 02:41 AM
Same frame, same engine, same problems my CRll had. Those heads are huge, and taller than the old push rod motors. My PCV valve still rubs on occasion on the underside of the hood. My frame mounts were cut off, and relocated lower, and further back, not to mention on a offset angle from each other.
When your motor is ready, drop er in the frame, and place the body back on the frame. Then take note of where ya need to make room for whatever is in the way.
Mark
