February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #21 (permalink)
Old 08-29-2002, 12:19 PM
ronzara's Avatar
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Ok,
while I am waiting to get a Lucas OFF-ON-ON toggle,... I bought a headlight switch from Advance, it has a 15 amp fuse built in, I connected the thing following the diagram, and when I pull it, to the 2nd (headlight) position,.. it pops the 10 amp (lo-beam) fuse in the Fuse Box... What the *X*X ??? ......Boy, does it get any easier????
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
  #22 (permalink)
Old 08-29-2002, 12:56 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
RZ, How many terminals and how did they tell you to wire it?
Don
  #23 (permalink)
Old 08-29-2002, 02:26 PM
ronzara's Avatar
Don,
It has the Battery In on Back End. Then 2 Prongs down each side. The Left - Rear Prong says PARKING LIGHTS. The Left - Front says HEADLIGHTS. BOTH Right prongs say TAILLIGHTS.
The the 15 Amp fuse runs down the middle.
I have #112 connected to the BATTERY IN.
#141 I attached to the HEADLIGHTS prong.
#171 I attached to the PARKING LIGHTS prong... POPPED 10 Fuse in Fuse Panel.
Then I attached #171 to TAIL LIGHTS Prong .. Still poped Fuse in Fuse Panel. .... I am lost here.
RZ
Ron Zara
ronzara@hotmail.com
  #24 (permalink)
Old 08-30-2002, 07:55 AM
dscott's Avatar
Did you try and touch #112 and #171 together? If the lights work then you know it's the switch hookup. If the fuse still blows then there's a short somewhere in the tail light circuit. I would check all the bulbs, I've had them short the circuit before.
Don
  #25 (permalink)
Old 08-30-2002, 12:53 PM
ronzara's Avatar
Don,
found the problem...parking light wires were touching....switch is working good. Thanks for your help. I hope I won't have to bug you for a while.
RZ
Ron Zara
ronzara@hotmail.com
