February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Old 06-26-2003, 09:51 PM
fxbill's Avatar
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Default FF Side pipes
Does anyone know how close a FFR side pipe is to fitting a Classic Roadster? I've made my own chambered mufflers similar to the stock set except with 2 1/4" louvered tubes in them... with the tubes end to end instead of side by side, but I need a set of pipes from the header flange to the collector. Since the price on them from FFR is very reasonable and they look close I was hoping their pipes would mount to the CR header...or at least be close and have the same collector length and size.
