January 2025
26 27 28 29 30 31
Old 06-22-2004, 01:23 AM
Post Speedo Cable Help!
Don or DV can you help!!
Hey Everyone! Well Gauge problems, Gauge problems!! What a pain in the butt! Change out the SW gauges for the B&B Faira Gauges. So far the only gauge that works is the tach. That is good...because that was the only gauge that wasn't working with the SW gauges. I'm sure the other ones will work after I remove my dash and rewire them.
Anyways.....My speedo cable is, how can I say this..SCREWED!.I think it twisted down close to the transmisson area...the cable seems to have a ripple in it....from the inside. I could see it from the out side.
I need another one...is there any automoblie cabes that will fit?
Don or DV can you help!!.....or anyone.
T5 trans with 302 H.O.
Thanks.
Snake/Gerry.
Old 06-22-2004, 06:20 AM
Ron61's Avatar
Post
Snake,
A friend of mine that has a 302 and the same tranny had no cable to start with. He bought one that he could cut to the right length and then put the one end on it. It has been working for two years now. This is just an alternative if you can't find one that is already correct for your car.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
