1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
10-11-2004, 09:53 AM
CO
Cobra Make, Engine: Classic Roadsters 427 C/O w/ Dual Quads
Roll Bar Third Leg Mounting
I would appreciate any pictures and specific installation information on how you mounted the third (rear) roll bar leg to the frame.
Thanks for your help.
Mike
10-11-2004, 02:53 PM
MN
Cobra Make, Engine: Owner, Classic Roadsters II
Mike, the 3rd leg is attached to the frame with a bracket. The manual tells you to mount the bracket to the frame with 3 self tapping screws. The 3rd leg is then attached to the bracket with 1 self tapper. Since the roll bar is sold as cosmetic only that was the way they did it. Many of the builders will weld the bracket to the frame and then drill through the bracket and 3rd leg and bolt it to the bracket. The manual has good pictures of the installation on pages 6-26, 6-27, and 6-28.
Don
10-11-2004, 04:45 PM
CO
Don,
As you mentioned-"Many of the builders will weld the bracket to the frame and then drill through the bracket and 3rd leg and bolt it to the bracket."
This is more what I'm thinking should be done, except I would like a MUCH heavier bracket.
Feedback please---Using 5/16" to 1/4" thick steel, weld a 4 sided box that would act as a base for the end of the 3rd leg.
The 3rd leg slides into the box.
Weld the box to the frame, and then-- drill through the box and the leg for a grade ( 8 ) bolt to tie the leg to the box?
Just want something a lot stronger than what was originally included on the car.
If anyone has pic's of their retro fit on this I would really appreciate seeing them.
Thanks, Mike
10-11-2004, 05:44 PM
TX
Mike,
Since I did not want a cosmetic roll bar, i welded an angle bracket to the side of the frame. On top of the angle bracket, i welded a 2" tall section of thick steel tubing, that fits inside the roll bar down leg. The downleg fits over the tubing, with a bolt through both to hold it in place.
John
6th generation Texan....
10-12-2004, 06:29 AM
CO
Hi John,
That could be a great solution. Any chance for a picture?
Thanks, Mike
10-12-2004, 08:00 AM
OR
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Check the ERA site for their roll bar installation. Theirs is a functional bar and anchors into a bracked in the trunk.
DonC
10-12-2004, 09:23 AM
CO
Hi Don,
I checked the ERA site bot do not find an illustration of the 3rd leg mounting.
Mike
10-12-2004, 10:43 AM
He
Cobra Make, Engine: Actual car: AC Autokraft MK IV with Keith Craft 331. Gone: Home built Crendon, original style twin tube frame, powder coated, stainless sidepipes. FE 433
Mike,
take a look on csxinfo.net.
A great source for infos like the requested.
http://www.csxinfo.net/427cobra/csx3...es/image13.htm
Greatings from Germany,
Uwe
Everything should be as simple as possible - but not simpler !!
10-12-2004, 01:21 PM
OR
Quick clip from the ERA Manual
This is a clip from the ERA Manual showing their attachment.
DonC
10-12-2004, 01:27 PM
CO
Vielen Danke, Uwe!
10-12-2004, 02:02 PM
CO
Don,
Thanks for the picture
