February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree1Likes
  #681 (permalink)
Old 01-14-2009, 07:04 AM
capteddie's Avatar
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Originally Posted by onefastmustang View Post
Good Luck.. I took mine and polished it.. I want to make rigid coolant pipes for my car next. I may have to go buy a bender now.. Gonna need a bigger garage soon.. :>)
You may want to talk to DV. He has a nice bender and he now has 1.25 and 1.5 dies. He's making rigid lines for me.... Well he will after I stop making changes to the setup
I'm right there with you on the bigger garage. I'm going to be starting a new home search soon and one major criteria is that it has a lot big enough to allow me to put a separate two bay shop behind the house.
Cheers!
"the other ed"
  #682 (permalink)
Old 01-15-2009, 07:39 AM
capteddie's Avatar
Default OK I'm with DV on this one....
DO TO THE WICKED A$$, BUTT FREEZING, GOD WINTER SUCKS WEATHER
DV is closing down his shop to ride out the cold and I have to agree with him
"the other ed"
  #683 (permalink)
Old 01-16-2009, 02:54 PM
wycobra's Avatar
Cobra Make, Engine: Classic Roadsters 351W stroked to 427
Default CRII Motor Mounts
Hey Other ED,
Have your been able to find the part number for the motor mounts that you bought from Jeg's for your car. Ed C. and Jeff Nelson have both assured me that the frame mounts that I have from CR are correct...i just have to find the motor mounts that go with them. Thanks....Mike
"If Things Seem Easy and Under Control, You're Just Not Going Fast Enough!" Mario Andretti
  #684 (permalink)
Old 02-02-2009, 03:56 PM
capteddie's Avatar
DV, was good talking to you today!!! Hopefully this weather is going to break soon and we can get some paint sprayed.
I ordered the new puke tank. You should have it by the end of the week. It has the thermostat housing built into it, so it should work fine.
Let me know if you need me to do anything with the bender.
Cheers!
"the other ed"
  #685 (permalink)
Old 02-04-2009, 04:22 AM
Double Venom's Avatar
Default Ronbo, et.al.,
Although cpteddie never said a word about the possibilities of the 'air cleaner' nuts coming off the studs and being sucked intothe carb, Ronbo had me questioning my own work! As said many times and hundreds of uses of the special flange nuts, I've never had one come loose! But this is a very critical point, it is to cold in the shop to do anyting but mechanical work, AND I looked at that air cleaner every day- what the hey! I took off the special nuts used large flat washers and normal nuts..............OK, absolutely 'Cobra like' now.........
DV
PS. 9's today. Going to 52' saturday-tha's norhern Mi.! At the end of the 'path' you can see Diane shoveling out the door to the shop! (God bless that women!) She's standing on at least 18"s of packed snow and ice!
  #686 (permalink)
Old 02-04-2009, 06:01 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Gee.. and it was so nice here today I took the day off and drove my cobra around.. I have a spare bedroom if you want to move.
  #687 (permalink)
Old 02-05-2009, 06:54 AM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
That really hurts
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
  #688 (permalink)
Old 02-06-2009, 06:50 AM
capteddie's Avatar
Hey DV!!! You around? or still out digging a tunnel to the shop
I think I remember during one of our chats. That you stated that after you cut out and reshaped the body area behind the seats, that there would be plenty of room for a much wider rear tire.
What size do you think would fit, without causing interference to the body or rear suspension?
Maybe.... P 315 / 60R15
Cheers!
"the other ed"
  #689 (permalink)
Old 02-06-2009, 10:15 AM
I need the actyuall width and height- then I'll know! ??
DV
Puke tank arrived. going to work just fine-I like it!
  #690 (permalink)
Old 02-06-2009, 04:56 PM
capteddie's Avatar
Here you go...
"the other ed"
  #691 (permalink)
Old 02-06-2009, 05:10 PM
Originally Posted by capteddie View Post
Here you go...
You building a car or a steam roller..
I used to have 295's on the back.. they were too wide cuz my ass end is too big.. I am actually tempted to buy another 8.8 and try narrowing it myself.. an experiment.. heh
  #692 (permalink)
Old 02-06-2009, 05:13 PM
capteddie's Avatar
Just want to make sure I have enough meat on the pavement
I have a narrowed 9", but if DV thinks its best. I'll drop back to 295s
Cheers!
"the other ed"
  #693 (permalink)
Old 02-06-2009, 05:28 PM
I would like to go back to the 295's myself.. someday..
  #694 (permalink)
Old 02-06-2009, 05:40 PM
capteddie's Avatar
Thanks for the feedback. Who's 295's would you use?
"the other ed"
  #695 (permalink)
Old 02-06-2009, 05:49 PM
I have BFGs on there and I find if I don't go crazy they work fine for me. but if I had another choice I would say Mickey Thompson...
  #696 (permalink)
Old 02-06-2009, 05:58 PM
capteddie's Avatar
The 315s are MTs. But it doesn't look like they make a 295/60, at least I couldn't find one at Summit. All I found was a 295/65.
"the other ed"
  #697 (permalink)
Old 02-06-2009, 06:02 PM
I think thats why I went with the BFG tires.. The local shop had them in stock the day I got my wheels and I was hot to get her into roller form..
  #698 (permalink)
Old 02-06-2009, 08:37 PM
MaSnaka's Avatar
Those MT"s (ET Street Radials) are sweet and sticky. I am running with 275's on the rear, 235's on the front and I really like them. They handle great in the turns, like to go straight on the fwy, no vibrations. I have never drifted with them in a turn because they hold on nice and tight and I haven't really forced the issue. The BFG's I had before would hold and then just let go. I like the MT's a lot. They look evil too.
John
  #699 (permalink)
Old 02-10-2009, 09:33 AM
capteddie's Avatar
DV I'm feelin warmer weather!!! It's 57 on this side of the lake
Now lets see how long it holds out
"the other ed"
  #700 (permalink)
Old 02-10-2009, 02:30 PM
Fella, We're breakin' records all over the west side of the State. Traverse City, North of us by a couple hundred miles is calling for 58 today! Heck we're not going to get that warm but mid 50's! But of course they are calling for more snow Thursday.
Ed, I ran MT street tires on my DV, you COULD NOT drive 50' in the rain. And I am serious. I drifted completely left of center crossing a bridge that had a built in 3-5 degree bank to it. The oncoming driver, thank my stars stopped, while I kept sliding off the wrong side of the road until I gravel and finally stopped.
Bright sunshine and no call for rain when the Mrs and I left.............
DV
