Old 08-17-2008, 07:40 PM
Default Addendum and other info in the manual
DV or anyone else,
The manual that I got from CRII does not have any of the addendum or other extra info that the manual says that is supposed to have, such as the carpet dimensions and layout, the dash layout or any other info. Does anyone have a copy of that information? My manual goes thru chapter 8. DV, I know that on another thread you mentioned the origional manual and a copied manual. Are they different?
Thanks, Terry
Old 08-18-2008, 08:19 AM
Double Venom's Avatar
Terry,
Much different, not better just different.
Gauges, lights etc, just make sure they are no higher than a half inch from the top or they will hit the cowl bar! Lay your dash in place, even without the body. then use the steering column hole to mount your three lights above it. If you do it first without the dash being in place you will driill them at an uphill angle! Usually the High beam will be just a little higher than the other two. Remember the 1/2" rule!
Carpet schematic, was NEVER close to begin with. Either an interior shop or if you can borrow someones and make life easy!
Gauges, just use your imagination! Lay them out like you would like them!
DV
Old 08-18-2008, 08:49 AM
Thanks DV.
Mine is already done. I was just trying to complete my manual.
Terry
