February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree2Likes
  #21 (permalink)
Old 03-31-2009, 05:31 PM
MaSnaka's Avatar
Gee CobraEd, I never even thought of that catastrophy. I have the center latch with the turn handles. Kinda redundant but if you don't know where to pull the cable from you can't open the hood, like DV said it keeps out the uninvited. Now if the cable breaks I'm screwed.
John
  #22 (permalink)
Old 03-31-2009, 08:46 PM
Double Venom's Avatar
Aah-Hmmm...,
If I may, may I stop this on-line panic mode about the steel cable (or other parts) breaking on the inside hood latch? Personally I have lost count on the hood latches -installed correctly- and later-now up to ten years later or more, I have never had one break....BUT-
If the system becomes unusable for any reason, go through the right vent! I assumed you/the builder used caulk to put the vent in place? Wiggle it loose, shove it to the inside and hey- you can reach the original hood box! You can take it apart through the vent-use a needle nosed vice grip-pair of pliers and pull the remaining cable to open....Cutting hoods to get open is NOT an option!
DV
  #23 (permalink)
Old 03-31-2009, 09:41 PM
Cobra Make, Engine: 91, 65 CR 427 289 or 302
Default Prop rods
Yes,
Count me in as interested in the stainless hood and trunk prop rods if they will work on a 91 (not shortened) CR. I have been using a 3 wood for the hood and a 5 iron for the trunk. They work better for me there than they do on the course.
Jim
  #24 (permalink)
Old 04-06-2009, 10:58 PM
Cobra Make, Engine: '91 Classic (shortened) 400 Chev 365hp, 400tq - Dynoed. Black/Black
Hey! STARWOLF56 / Charlie
Got the parts today. Still can't believe it! Can't wait to run them down to Wannamingo tomorrow where my car is.
Thanks! U-da-man!! Someday... pics!!
-John
  #25 (permalink)
Old 04-07-2009, 07:05 AM
Cobra Make, Engine: Classic, 347
Lot of Corvette guys had your same concern, Ed. It was pretty common to run a secondary pull wire that you could reach from under the car. Note that Corvettes have two latches, so it was more likely to happen with these.
Regards.
  #26 (permalink)
Old 04-07-2009, 10:11 AM
MaSnaka's Avatar
I like DV's don't panic attitude. I was looking at the assembly with another local CR owner at our tri-county club get together this weekend and saw that the latch receiving end was bolted to the firewall/body in a manner that the 4 bolts could be removed from under the dash and popped out. Hence lifting the whole assembly upwards. The only hitch was the receiver has a flange on the top that could interlock with the lip of the fiberglass body where it comes over the firewall. I'm not saying it would be easy, but between that and the side vent access there are options other than cutting. Keeping the whole assembly properly lubed will ease the operation of opening and closing the hood. My cable run is very short with the pull centered under the dash fwiw.
John
jaydonaldson likes this.
  #27 (permalink)
Old 04-08-2009, 05:02 AM
starwolf56's Avatar
Cobra Make, Engine: Classic Roadster,351w 405HP
John, Glad to help! I've been there too... Charlie
To those that requested hood and trunk prop rods.... I'll bend up some more and they will be sent out next week. Jim I do not have a address. CR
  #28 (permalink)
Old 04-08-2009, 07:11 AM
CobraEd's Avatar
I never realized that all the Corvettes had the same potential problem with the rear latch. That is how many millions of cars. Maybe I just worry too much.
DV, I still like your exterior dual latch solution. How are the handles mounted to the hood??? Little self taping screws, or bolted all the way thru??? Obviously, you dont want that handle rocking on the hood under the presure of the hood trying to move around when driving.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
  #29 (permalink)
Old 04-08-2009, 03:26 PM
CobraEd,
See cpteddies huge post last page opr so shows the entire deal.
DV
PS- yep very familiar with the single cable duel pull on the corvettes-never had one of them brake either
  #30 (permalink)
Old 04-08-2009, 05:11 PM
CobraEd's Avatar
Neutral
Originally Posted by Double Venom View Post
CobraEd,
DV
Yep, I already looked at that post. But I only looked at the pictures! I didn't read the text about the screws and nuts. (They don't call me "Special Ed" for nothing)
________
________
  #31 (permalink)
Old 04-14-2009, 06:49 PM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
ShortCR. Post a pciture of your car when you get a moment. I would like to see it.
  #32 (permalink)
Old 04-18-2009, 11:08 PM
Hi Curt C,
I don't get on here as much as I would like to. If I can figure out how to add pics here, I will as soon as I get something reasonably useful
I thought that sooner or later, somebody wourl be curious about what a short CR looks like.
Thanks for your interest. This is really a fantastic site!
John
  #33 (permalink)
Old 04-18-2009, 11:09 PM
I tried. My pics are 2.35MB JPEG's. Don't have a clue how to make them acceptable to this site.
John
  #34 (permalink)
Old 04-18-2009, 11:27 PM
MaSnaka's Avatar
Hey Short,
Go to forums and find "all cobra talk" There is a sticky about 3 down that explains the whole process. I know they have to be reduced some before you can upload them. Hope that helps.
John
  #35 (permalink)
Old 04-20-2009, 12:29 AM
Thanks John (MaSnaka).
Let's see how this works...
These pics won't really show anything anyone is looking for. They were taken over a year ago when it was painted.
I'll repost when I get better ones.
Nope. I have the resized pics. When it asks for the "URL" when I click "insert image"...I am lost. To make matters worse, my 5 year old neighbor who used to show me this stiff .. moved away!!!
