March 2025
30 31
Old 06-13-2009, 10:33 PM
Default Door Hinges
Would anyone have a set of door hinges that I could borrow or buy. I am trying to figure out a way to change the way the door opens. So the whole door swings away from the body instead of the front turning into it. I really do not want to remove my doors yet.
Terry
Old 06-14-2009, 03:03 AM
Double Venom's Avatar
Terry,
Sorry I can't help. But the idea is a good one! My thought is to have a "U" built into the hinge just to the rear of the front mounting with the "U' facing toward the door. (Room for this under the dash area for the top one.) This would allow or force the door to move outward from the front fender before actually opening to 'wide posistion'. (Did this type of thing on a '34 Ford Cp and a '40 Willy's I built.) Keep us posted fella, this is a good idea!
DV
Old 06-14-2009, 06:09 AM
1985 CCX's Avatar
Terry
Call Nick as he makes them OEM Cobra style.
http://www.actoncustom.com
Old 06-14-2009, 09:08 AM
Jeff,
Thanks for the link. I believe that the Classic Roadster door hinges are different from most. Will be worth checking into though.
Thanks again,
Terry
Old 06-14-2009, 12:04 PM
Terry,
I have never seen a 'like' door hing to CR's massive hinge, but doesn't mean they can't be made!
DV
Old 06-14-2009, 01:20 PM
tcrist,
How much more room do you figure a different arrangement might give the opening? What is your purpose for the change? Just curious.
Old 06-14-2009, 01:28 PM
DV,
I can make them if I can get it designed correctly. I would like to look at what Emerson Motorsports did to theirs. This is the way theirs works from what I understand.
sdfletch,
The purpose is for the whole door to open away from the body. Probably will not give you much more room to put your legs the door opening in the body. But it would swing the door further out away from the body. More like a standard car door opens.
Terry
Old 06-14-2009, 01:39 PM
tcrist,
Sorry, still confused. If the door works now without a mod, what is the purpose? What am I missing. DV says it is a good idea. Must be part of a larger plan, imo.
Old 06-14-2009, 01:56 PM
If your door is out of alignment by very little then the extended part of the door hits the body when you open it. Been there, done that. On the top of the extended area.
Edit: This could move the door about 6 inches further away from you when the door opens. The door opening in the body is the same size but it will feel like you have a lot more room. I think.
Terry
Old 06-14-2009, 02:30 PM
Thanks. I guess I am into this conversation a bit late.
Old 06-14-2009, 02:42 PM
Not really, I just brought it up today.
Emerson has done the same thing (their doors are shaped similar to the CR's but longer I think). They say that it does give you more leg room. If their doors are longer then it would.
It is just a thought that I had and wanted to look into it further. I think it would give you more knee room when you are getting in and out.
If it does not work then I am only out a little time and money. I work at a precision sheet metal shop and we have lasers, machining centers, welders, ect. So it would not be that hard to do.
I am a CAD designer so I have the latest software to play with.
Terry
Old 06-14-2009, 03:04 PM
Terry,
I'd love to draw you a picture of what I THINK would work but, one thing I can not get "Paint" to do what and two... I would be too embarssed to draw a picture for you!
If done correctly the door would open at least two to four inches away from the body instead of millimeters!
Tons of more troom for ingress/egress!
DV
Old 06-14-2009, 03:30 PM
DV,
If I am thinking correctly, The hinge pin needs to be by the body and forward of the door extension. You would come from there back towards the interior bent in a "U" shape to where the bracket mounts to the door. The edge of the fender would actually fit into the "U" when the door is opened. That way when the door is opened the extended part of the door would be outside the fender with a gap. 1 to 2 inches should do it.
Hope I have not confused you.
Terry
Old 06-16-2009, 07:10 PM
63mercury's Avatar
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
I will try to post a pic of the FFR hinge I took at London a couple years ago, maybe it will help. Carl
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
Old 06-16-2009, 07:16 PM
Thanks Carl,
The design is kind of what I thought it needs to be like to get the correct swing.
Now I just need to have someone let me borrow their Classic Roadster ones so I can make 3D cad drawings of it and then modify the drawings.
Thanks again, Terry
Old 06-20-2009, 10:49 AM
Cobra Make, Engine: Classic Roadsters, 351w
Boy, I would be interested in a set of those if someone manages to get something to work!!
The "extension" part of my door fits so closely that it does rub at the top with the body, so any improvement in that plus "leg room" would be very helpful.
Old 06-20-2009, 02:33 PM
Relatively easy to do, but one needs a hinge to play with.
DV
Old 06-20-2009, 05:52 PM
I guess I will pull one of my doors off and remove the hinge so I can make a 3D model of it. I can then modify the model to change the pivot location.
Thank you to Ital-Cobra for sending me pictures of the Emerson Motorsports door and hinge setup so I could get an idea of how they did theirs.
Terry
Old 06-20-2009, 07:34 PM
Terry,
You certainly have my attention!
DV
Old 06-28-2009, 07:56 PM
I now have a set of door hinges to play with. Thank you jagrolet. Now to try and re-engineer them a bit.
Wally (jagrolet), thanks again.
Terry
