1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
11-17-2015, 01:33 PM
Senior CC Premier Member
CA
Another Newbie just passing through? Or are you really looking for help?
11-17-2015, 04:07 PM
AL
FE built
Keith Craft
11-18-2015, 09:31 AM
Sorry guys, busy with work. But appreciate greatly the level of help offered. Here are the pics. In one pic you will notice a chipped cylinder wall at the very edge and wondering if that is a problem. Also I remeasured the bore (4.051) and it is definitely a 390. I wire brushed the block ID. What do you think ?
11-18-2015, 09:33 AM
more pics...
11-18-2015, 09:38 AM
Let me know if more detailed pics are required... Thanks again.
11-18-2015, 11:26 AM
CA
None of my reference documents indicate a 390 with an "H" designation. But that doesn't mean it didn't exist. Hopefully someone here has other references. Thanks for posting the pics. Looks like a hydraulic cam motor as well.
11-18-2015, 02:14 PM
The subject comes up every so often on the Ford FE forum. Here's on example (a search will bring up more): 332-428 Ford FE Engine Forum: Ford/Merc High compression 390 2V revisited. Shoe, do you have another great story
11-18-2015, 02:24 PM
CA
I was referring to the "H" at end of the block casting number....
11-18-2015, 09:07 PM
Interesting information... Thanks fellas.
01-20-2016, 10:09 AM
AL
I have a 428 block out of a 67 station wagon. It has the bosses cast in the block for cross-bolting.
It's my understanding that to cross bolt a block the block had to the bosses cast in place.
You can not take just any 390 block and cross bolt it. Correct?
Dwight
01-20-2016, 11:42 AM
TN
Cobra Make, Engine: Scratch-built 427 MR
Early 427's had solid lifters, not hydraulic like this block. Also the crossbolt holes were countersunk. Your crossbolts are surface mounted.
