February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
  #41 (permalink)
Old 11-23-2010, 11:18 PM
Dominik's Avatar
Position the bellhousing 2 feet and 8,5 inches from the front axle centerline.
I look up the crank centerline height from chassis (or ground) another day, remind me.
"Join" the scratch builders section in this forum.
If I don't respond anymore, that's because I can't log in
  #42 (permalink)
Old 11-24-2010, 06:46 AM
Just a thought, you might want to make that trans mount cross bar removable. If for some reason you need to remove the trans after it is together it could make it a lot easier.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
  #43 (permalink)
Old 11-24-2010, 08:34 PM
Cobra Make, Engine: not mine but my bosses cobra kit car
Default todays progress, had to adjust ride hight
I was in the shop by myself to day so I had to get a little creative with getting the body off the frame by myself. I got the modified mustang gas tank installed.
  #44 (permalink)
Old 11-24-2010, 08:48 PM
how do I get to the scratch builders section, I cant find it? thanks
  #45 (permalink)
Old 11-24-2010, 09:51 PM
Here you go,
http://www.clubcobra.com/forums/scratch-builders-forum/
Terry
  #46 (permalink)
Old 11-27-2010, 02:08 PM
Hey thanks for the tip. I'm will continue my progress here, in the from scratch section.
http://www.clubcobra.com/forums/show...10#post1092310
knowledge is power, power is speed, and speed is good.
