1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
440Likes
07-28-2013, 09:16 PM
CA
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
Hi Glen-
Transmission is a T5z. Need that OD for the freeway
Rear end is an aluminum 8.8 center section equipped with 4.10 gears
Engine is a 331 stroker.
Trick Flow CNC'd 205cc heads
Lunati hydraulic roller cam (.571/.587 lift, 282,292 adv dur, 112 LSA)
SCAT forged steel stroker crank
Probe forged steel I-beam rods
Lightweight floating wrist pins
Probe forged aluminum domed pistons (11.5:1 static compression)
Aviaid original style oil pan
Blue Thunder dual quad hi-rise intake (port matched)
Two Holley 450 CFM carbs
07-28-2013, 09:43 PM
NH
Nice work.
07-29-2013, 02:35 AM
OR
Looks like fun!
ERA FIA 2088
10-16-2014, 09:52 AM
CA
Deleted
10-16-2014, 09:59 AM
CA
Stewart Transport picking up the car from Bruce
Two hoods. One traditional, the other with louvers
10-16-2014, 11:33 AM
TR
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
great milestone, what about chassis ?
10-16-2014, 12:36 PM
CA
The chassis is a highly modified Factory Five chassis
10-16-2014, 04:27 PM
tx
Finally, an update!
Looking good. Love the molded in hood louvers.
Good to hear from you, hope things are going well.
10-16-2014, 04:53 PM
CA
Thanks Dallas. Car should be here by the 27th. Very excited
11-04-2014, 05:32 PM
CA
The car has finally arrived! It was picked up from Mr. Bruce's house Oct 14 and delivered Nov 2. I have a lot of work ahead of me. More of a journey.
Here it is sitting comfortably in my garage while I inventory everything.
Until I get my motor mounts which are needed to install my plastic engine to mockup my exhaust system, I began removing unneeded pieces on the frame from FFR. These include roll bar stubs, remnants from pieces removed by Bruce, and the 4" round front cross member
11-04-2014, 05:34 PM
CA
I was tired after a full day of grinding and sanding so decided to play with some red tape I had laying about
11-19-2014, 09:28 AM
CA
Finished making the trunk templates. Time to buy a HF sheet metal brake and make some aluminum panels
Update: I made my own sheetmetal brake 37" wide and began making my aluminum panels. Nothing from FFR is usable.
11-19-2014, 12:30 PM
tx
Looks good Bill.
Originally Posted by Bill D
Time to buy a HF sheet metal brake and make some panels.
How in the world did you complete all your other builds without a brake??
12-01-2014, 06:37 PM
CA
Originally Posted by dallas_
Looks good Bill.
I made one from heavy duty angle iron. I will probably make another one for this build
12-02-2014, 06:35 AM
NH
Coming along nicely
12-02-2014, 02:59 PM
CA
Thanks 1985 CCX. Trying to source original style hood hinges and mounts since none came from Bruce. This has me backed against the wall as I have no idea what to do
12-02-2014, 04:20 PM
Ca
Cobra Make, Engine: SPF GT40P-2265/393W, KMP318 (PROJECT!!!!!)/CSX478
Have you tried the Kirkhams? They seem to have a line on such things for their own cars. In my experience, they have been helpful to non-Kirkham owners.
Ron R
"Dishwasher? I thought that was for cleaning parts!?"
12-02-2014, 05:14 PM
CA
Thanks Ron
12-02-2014, 08:31 PM
CA
I ordered sheets of .060 aluminum to start making the panels. Should keep me busy for awhile
12-14-2014, 02:48 PM
CA
Talked to Bruce and he is making me hinges. There was a miscommunication and he thought I was going to use the FFR hinges. His are much nicer and more original. Now just have to wait till they show up
