March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Like Tree440Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
  #41 (permalink)
Old 12-14-2014, 02:54 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
While I'm waiting for the hinges, I bought materials to fabricate the lower radiator mount. I cut some .080 mild steel flat stock to length, drilled the mounting holes, rounded the ends, then carefully measured and welded the tabs. Drilled holes in the stubs on the radiator for 1/2" hitch pins. Assembled with rubber grommets, the mount, flat washers, and secured with hitch pins.
I'll cut the bar to length and weld on mounting flanges once I'm certain the position of the radiator.
  #42 (permalink)
Old 12-16-2015, 08:30 PM
Bill D's Avatar
It's finally beginning to look like a real car
  #43 (permalink)
Old 12-16-2015, 08:47 PM
Bill D's Avatar
Got my Blue Thunder intake manifold from the machine shop where they port matched and blended the individual runners
Topped off with 48 IDA Webers. Just waiting for my "Octopus" water/fuel inlet and linkage components from Jim Inglese
CompClassics and Winchester67 like this.
  #44 (permalink)
Old 12-17-2015, 12:47 AM
xb-60's Avatar
Bill - I'm envious! You will end up with a very nice FIA replica there.
Glen
Bill D likes this.
  #45 (permalink)
Old 12-17-2015, 03:53 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Your build looks great, congrats on your accomplishments.
Bill D likes this.
  #46 (permalink)
Old 12-17-2015, 04:33 AM
1795's Avatar
Looking fantastic, keep up the good work!! Can't wait to see it altogether.
  #47 (permalink)
Old 12-17-2015, 10:22 AM
CompClassics's Avatar
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
I sent you a private email.
  #48 (permalink)
Old 12-17-2015, 02:42 PM
1985 CCX's Avatar
After all that you need the right alternator bracket..... Looks like GT350 set up...
Looks fantastic, awaiting more updates.
CompClassics likes this.
  #49 (permalink)
Old 12-17-2015, 03:09 PM
*13*'s Avatar
289 with Webers. Makes you want to drive around without the hood.
ERA FIA 2088
  #50 (permalink)
Old 12-17-2015, 04:31 PM
LightNFast's Avatar
Cobra Make, Engine: Viking Blue "64" 289 FIA comp car by Superformance #0002, Keith Craft - 331 (460HP), Jim Inglese - 48IDA Weber carbs, BW T10 4spd.
Just a photo of loose hardware near open Webers makes me nervous! .... Joking aside, she's looking good Bill .
  #51 (permalink)
Old 12-26-2015, 02:00 PM
Bill D's Avatar
Got my FIA water/fuel inlet from Jim Inglese today, along with gaskets, reproduction fuel line clamps, banjo fittings, and correct water hose clamps.
  #52 (permalink)
Old 12-26-2015, 02:32 PM
LMH's Avatar
LMH LMH is offline
Looking good!
Alba gu brąth
  #53 (permalink)
Old 12-26-2015, 03:52 PM
1985 CCX's Avatar
Bill
Awesome.
Call Racewhere for correct alternator bracket.
You've come this far might as well complete the mission.
Bill D and CompClassics like this.
  #54 (permalink)
Old 12-26-2015, 03:58 PM
*13*'s Avatar
Nice looking parts!
ERA FIA 2088
  #55 (permalink)
Old 12-26-2015, 05:41 PM
I would recognize that fuel log / water pipe anywhere
I want to give Dan Case credit here as he worked with me on both of these brass / steel fuel inlet banjo projects....
LMH likes this.
  #56 (permalink)
Old 12-26-2015, 05:49 PM
Bill D's Avatar
I haven't purchased the rubber fuel hose yet. Is it just plain ol' rubber fuel hose that I can get at Napa or Autozone?
  #57 (permalink)
Old 12-26-2015, 06:09 PM
The best hose that I have found is the Aeroquip...Neoprene
  #58 (permalink)
Old 12-26-2015, 06:13 PM
Here is a photo of our alternator bracket, we supply original parts and concours level reproductions of a number of 289 Cobra related products.....carb linkage, oil coolers, upper radiator hose couplings (with SW bung), etc.
  #59 (permalink)
Old 12-27-2015, 02:28 PM
Cobra Make, Engine: ERA 2092
Does the alt bracket work in a era slabside
  #60 (permalink)
Old 12-27-2015, 02:32 PM
1985 CCX's Avatar
It should.
This is a 289 Cobra only part.
Rate This Thread:
