December 2024
Like Tree24Likes
  #21 (permalink)
Old 06-02-2016, 01:19 PM
Cobra Make, Engine: ERA 806, KC 482 FE
Congratulations
I finished ERA 806 last year with almost the same options except quick jacks, no seat heaters or radio. I did add the HD radiator, big brakes and the .64 5th with 3.54 ERA rear. Connecticut Custom painted it Guardsman Blue with white stripes and did an incredible job. How much of the build are you going to do yourself?
Gary
cobra likes this.
  #22 (permalink)
Old 06-02-2016, 03:15 PM
RodKnock's Avatar
Guardsman Blue is always a safe and solid choice. Looks great!
My only small quibble with Gary's and Bernica's cars is that I would choose white sidepipes, or black, if I had their shades of blue paint. But that's personal choice, of course.
  #23 (permalink)
Old 06-02-2016, 03:19 PM
Bernica's Avatar
Senior CC Premier Member
I'm doing new pipes now and both are my choices. Love the white.
  #24 (permalink)
Old 06-02-2016, 03:31 PM
RodKnock's Avatar
Excellent!
Now I'm thinking you need a Cammer too.
Gasdoc, it's not too late.
  #25 (permalink)
Old 06-02-2016, 03:41 PM
Bernica's Avatar
Excellent!
Gasdoc, don't listen to him! A Cammer is the last thing you need!
A stroked Windsor should do you just fine IMHO.
  #26 (permalink)
Old 06-02-2016, 05:54 PM
Dimis's Avatar
BAN HIM!! BAN HIM NOW!!!!
  #27 (permalink)
Old 06-02-2016, 05:57 PM
Bernica's Avatar
Ouch DIMIS! You know what I really wanted to say, but he doesn't need it.
  #28 (permalink)
Old 06-02-2016, 06:06 PM
Dimis's Avatar
Oh PS: Yes Welcome GasDoc!
Thanks for sharing your build. You've seemingly made great choices all-round. Congrats and best wishes.
I still loves ya!
Alan and I are within 45 minutes of each other, so we're used to the same roads. If we drive 80-85, more than likely we'll end up in jail.
Probably cos you're runnin' moonshine in the boot/trunk...
Just on noise & gear ratios at 75-85mph the wind is often loud enough...
  #29 (permalink)
Old 06-03-2016, 09:33 AM
davids2toys's Avatar
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
I would go with 331 gears and the .82 OD
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
  #30 (permalink)
Old 06-03-2016, 10:22 AM
RodKnock's Avatar
I'd rock the Toploader instead. If you're going to go with the old school engine, seems incongruous to install a 5-speed in there.
Just ask Bernica, that Toploader shifts like a hot knife through butter.
  #31 (permalink)
Old 06-03-2016, 10:34 AM
Bernica's Avatar
I run 3:31 and the WR toploader and yes, it "shifts like butta!
  #32 (permalink)
Old 06-03-2016, 01:07 PM
TKO shifts like a hammer in a bag of rocks
blykins and Bernica like this.
  #33 (permalink)
Old 06-03-2016, 01:59 PM
RodKnock's Avatar
You must have purchased the very special M22 Rockcrusher edition of the TKO.
For "old world" consistency sake, I'm the one pushing for the Toploader in Gasdoc's ERA. It shifts like fart permeating a small car with the windows rolled-up, A/C off, on a hot summer day.
KevinW likes this.
  #34 (permalink)
Old 06-03-2016, 02:14 PM
Bernica's Avatar
Where the magic happens!
David Kee Toploader Transmissions, Inc.
  #35 (permalink)
Old 06-03-2016, 02:17 PM
Bernica's Avatar
I should say the "Real" magic!
  #36 (permalink)
Old 06-03-2016, 03:13 PM
Cobra Make, Engine: ERA FIA #2064 BOSS 302 CSX2047 sold
I also have a 3:31 rear with a .68 behind a Tremec TKO. The first 4 gears
are almost the same as a wide ratio toploader except for 1st which is lower
@ 2.95. I use it like a 4 speed with 5th just as an OD cruising gear that
results in a very quiet 2200 RPM at about 70MPH.
Bernica likes this.
  #37 (permalink)
Old 06-03-2016, 07:36 PM
Cobra Make, Engine: ERA #813, 427 FE Sideoiler
I've tried to post a reply a couple times to some of your guys questions using the quote and multiple quote buttons and I keep getting some message about waiting for moderator approval. Whats up with that?
  #38 (permalink)
Old 06-03-2016, 07:45 PM
I talked to Peter at ERA today and they are bonding the body to the frame on Monday and hopefully it will be ready to go to Connecticut Customs within a few days after that. When I talked to CC a couple weeks ago, they told me once they get the car to expect the paint process to be 4-5 weeks. I do plan on doing the assembly myself. I also asked Peter about a HD radiator and he didn't seem to know what I was talking about. Heavy duty fan maybe? I did order the dual front fans, but he said those were mostly for looks. Lippy - tell me about the wool carpet. Peter kinda steered me away from it and said the regular carpet would blend better overtime and the wool tends to fade a bit in the sunlight. I love your guys cars! I hope mine turns out looking half as good as some of the pics you've posted.
  #39 (permalink)
Old 06-03-2016, 07:52 PM
It's a bigger fan, not radiator. Ten years ago it was a SPAL 30102120. Go for it, even with the dual pushers. I have my pushers wired so that they only come on when the manual override switch is engaged. Don't go with the wool carpets -- bugs will eat it and it smells funny when wet.
  #40 (permalink)
Old 06-03-2016, 08:05 PM
Thanks Patrickt. Where did you put the manual override switch?
