April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Like Tree390Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
  #181 (permalink)
Old 01-07-2020, 05:38 PM
xb-60's Avatar
Finishing the insulation in the tunnel. Tight spot for access, but worked out OK.
33degC so getting a bit warm in the garage...under the car...
  #182 (permalink)
Old 01-07-2020, 06:12 PM
1795's Avatar
Glen,
You need higher jack stands! It looks like that car is sitting just inches above you. Awful tight place to be working.
Jim
  #183 (permalink)
Old 01-07-2020, 07:44 PM
xb-60's Avatar
Higher off the floor would be a little easier, agreed. For the most part though, I'm sitting on the floor in the engine bay and just reaching into the tunnel to install the insulation.
That's it for the sheet insulation, but there are stainless steel panels still to be fitted over the insulation on the firewall and the footboxes.
Glen
  #184 (permalink)
Old 01-13-2020, 05:56 PM
xb-60's Avatar
This week's update...
Working on the dash and gauges. That horizontal crossmember behind the dash that I had to work around for the glovebox is causing 'challenges' for my speedo as well. All other gauges fit OK, but having to use an adaptor to 'move' the location of the speedo a little lower to clear that tube.
My story is that the adaptor that I'll have to make adds to that modified ex-racer look of the dashboard.
Cheers!
Glen
1985 CCX and Bill D like this.
  #185 (permalink)
Old 01-13-2020, 06:10 PM
BJ's Snake's Avatar
Can't just notch out the cross member for clearance?
289 FIA Cobras RULE!
  #186 (permalink)
Old 01-13-2020, 06:57 PM
xb-60's Avatar
From memory the tube is around 30mm diameter and I would have to notch out around 12mm or thereabouts to clear the speedo cable.
It's a structural member, so don't want to do that. I don't want it to bite me back one day
Glen
  #187 (permalink)
Old 01-14-2020, 05:51 AM
peterpjb's Avatar
nice fuel pressure gauge
xb-60 likes this.
  #188 (permalink)
Old 01-16-2020, 02:48 AM
xb-60's Avatar
Thanks Peter. They are not very common
Finished the under-hood insulation....finally....
Glen
  #189 (permalink)
Old 01-16-2020, 04:12 PM
Gaz64's Avatar
Although I think it is mechanical, I hope it is electrical, for safety.
Jaydee likes this.
Gary
  #190 (permalink)
Old 01-18-2020, 02:05 AM
xb-60's Avatar
Hey Gary!
Yes, it's mechanical ....hey, it's a Cobra (replica)....we don't use that modern electrical stuff on gauges.
Yes, the gauge is decades old, and exactly as used on FIA cars.
If it's ever actually connected up (the gauge), my engine will need to be carb'd, not EFI....which I hope to be able to do eventually (carb fueled) if our SA club is successful in it's negotiations with the state rego boys.
....and if so, no, for safety, the fuel will not go any further south than the firewall, so should be quite safe enough to satisfy my compliance engineer, as well as me
Glen
Gaz64 likes this.
  #191 (permalink)
Old 01-18-2020, 03:22 AM
Cobra Make, Engine: CR Cobra 3169
My dyno guy said with the right cat it should pass emmisions with a carby. JD
  #192 (permalink)
Old 01-18-2020, 06:12 PM
xb-60's Avatar
JD,
If I go the 'standard engine' route, there's a simple idle emissions check and a noise check as my engine is ADR37/01 compliant. Easy.
If I go the 'carb' route, it would most probably require multiple dyno tuning sessions, and then an IM240 test. Expensive. One of our club members has done this, and it was a long, long road. Again....expensive.
As I mentioned previously, our club is in conversation with our state DPTI regarding emissions (and other) standards for ICVs; with a degree of luck, we may gain some worthwhile concessions that would allow carbies to be used. I'm not looking for power, I'm looking for something that looks more period correct than a modern EFI sitting on top of the engine
Glen
Jaydee likes this.
  #193 (permalink)
Old 01-20-2020, 10:49 PM
xb-60's Avatar
Originally Posted by xb-60 View Post
....Finished the underdash insulation....finally....
Just kidding ...it's still happening.
The SS firewall sheet is now back in, and I'm working on fitting the SS panels that cover the aft part of the engine bay.
Cheers!
Glen
  #194 (permalink)
Old 01-27-2020, 02:58 AM
xb-60's Avatar
Might seem to be a backward step to 'de-polish' SS heat shields.... but it's just too shiny for a Cobra....
  #195 (permalink)
Old 01-27-2020, 03:00 AM
xb-60's Avatar
....and here's the same panel, 'scuffed'....
Bill D likes this.
  #196 (permalink)
Old 01-27-2020, 04:10 AM
1795's Avatar
Glen,
You do attend to detail that others may pass on addressing. Looks nice, but I bet you some day you are going to regret it. There will be something down low that you want to see that a little extension mirror will not reach, and you will say, "Damn, I shouldn't have scuffed up that nice shiny stainless steel."
Keep up the good work.
Jim
  #197 (permalink)
Old 01-30-2020, 03:13 PM
xb-60's Avatar
Jim,
To quote Mr. Joel..."You may be right, I may be crazy" and/or "You may be wrong for all I know, but you may be right"
....I'm just thinking of the horror of lifting the hood and getting my reflection back at me from half a dozen mirror-finished panels. Enough to drive a man to another beer
Here's cheers!
Glen
  #198 (permalink)
Old 01-30-2020, 03:36 PM
1795's Avatar
Here's cheers!
Glen[/quote]
Glen
That has always been a short drive for me. Here's cheers to you as well.
Jim
xb-60 likes this.
  #199 (permalink)
Old 02-02-2020, 03:42 PM
xb-60's Avatar
I've covered making/installing a footrest elsewhere in a separate thread.
I'm adding the 'result' here as well to include it in the build thread...
  #200 (permalink)
Old 02-16-2020, 05:37 PM
xb-60's Avatar
Nice to be here again
Been working on my front inner guards.
I thought this would be easy but I think the panels supplied were to suit the profile of 427 guards, so long story short, it took a long time, and only the left side so far.
Here the outer view....
Rate This Thread:
