January 2025
26 27 28 29 30 31
Like Tree390Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
  #521 (permalink)
Old 04-10-2022, 08:31 AM
tkb289's Avatar
Originally Posted by xb-60 View Post
... Tim, I took your advice. As posted previously, I did that 'black paint' comparison..... which resulted in pulling out the adapter ring and repainting it today.
The result is definitely better ...
Glen
Glen,
That looks great and the adapter ring blends in much better with the dash now, well done.
- Tim
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
  #522 (permalink)
Old 04-10-2022, 11:10 PM
Harpoon PV2's Avatar
Well, as much as you tried, I don't think you captured the art of the original Shelby installation! Amazing how down and dirty it all was back then, even taking into consideration, the aging proses! Cheers, Dennis
tkb289 and Alfa02 like this.
  #523 (permalink)
Old 04-11-2022, 12:03 AM
xb-60's Avatar
Dennis - very funny.... LMAO
Related to Dirtbag, maybe??
Harpoon PV2 likes this.
  #524 (permalink)
Old 04-13-2022, 02:54 AM
xb-60's Avatar
There is still a 16g aluminium alloy panel to be mounted on the top of the tunnel, but finally able to do a trial fit of my stopwatches...
Cheers!
Glen
edit: a couple of extra pictures added
dash with stopwatches...
tunnel "trim" panel in place...
(have now drilled holes in this panel to accomodate stopwatch bracket)
1795 and Harpoon PV2 like this.
  #525 (permalink)
Old 04-13-2022, 11:11 PM
Love the twin period stop watches! Cheers, Dennis
  #526 (permalink)
Old 04-19-2022, 05:07 AM
xb-60's Avatar
Any bright ideas on how to make the stopwatches more secure? Currently they're secured in place with spring clips.
I'm thinking maybe three hollow 'posts' (like spacers) per stopwatch, with a screw through each spacer, securing through to the main panel; screw heads to overlap the stopwatches to make removal "difficult".
Any better ideas most welcome
Update on engine and gearbox....
Both are ready to be introduced to each other, but my favoured workshop has/had 6 out of 8 mechanics off work with COVID or as 'close contacts'. Commitments there are banking up
Car itself is ready to go there when their workload permits.
Glen
  #527 (permalink)
Old 04-19-2022, 11:12 PM
I think you are on the right track. You could make some crescent moon peace's of metal, that would follow the bezel on the watches. Make them wide enough for the screw to go through the crescent on the outside edge of the watch and then do what you are thinking of doing, drill and tap the back plate with spacers. I think that would make it pretty hard to pilfer! Cheers, Dennis
xb-60 likes this.
  #528 (permalink)
Old 05-01-2022, 03:18 AM
xb-60's Avatar
Today's job - fit switch knobs.....
The ignition switch is around the place somewhere, just got to find the "safe place" where I put it some years ago
Cheers!
Glen
edit: still no update on when my mechanic will be available
  #529 (permalink)
Old 05-04-2022, 05:50 PM
xb-60's Avatar
Back to the stopwatch security issue, I added 3 x M5 screws to each stopwatch, with nyloc nuts on each side of the mounting panel.
Glen
  #530 (permalink)
Old 05-04-2022, 10:58 PM
Attachment 37538
Glen
Looks good, Kiss (keep it stupidly simple) method! Should keep them in place, and stop them from walking away from the car! Cheers, Dennis
  #531 (permalink)
Old 05-14-2022, 07:24 PM
xb-60's Avatar
Yes, I know this is "belts and braces" ....but I like Cole Hersee switches, and it adds an extra degree of security. It will be mounted in the trunk.
Cheers!
Glen
Alfa02 and Harpoon PV2 like this.
  #532 (permalink)
Old 05-14-2022, 08:21 PM
tkb289's Avatar
Glen,
Great idea and well executed.
Having a master switch to disconnect the battery is a good idea for many reasons. The two primary benefits are being able to safely work on the electrical system and as you mention, a security device.
- Tim
xb-60, Alfa02 and Harpoon PV2 like this.
Build Log:
  #533 (permalink)
Old 05-19-2022, 04:46 AM
xb-60's Avatar
Thanks Tim. However, now with a few days to think about it......
A further development here ….. I'm now looking for a different location for my battery disconnect switch.
Why? Well the continually developing story is – I started investigating where to run the battery cable from the battery's current location in the trunk, forward to the engine bay. Sounds easy, but my ‘chassis’ is a semi monocoque, and the routing of a substantial cable almost the full length of the car in a safe manner is far harder than I thought. Hence, considering locating the battery on the floor in the passenger’s footwell. It will fit easily, access will be adequate, securing it should be easy enough ….and importantly, the route of the battery cable will be short, direct and easy.
Now the problem is where to locate the battery disconnect switch in a safe and secure place but that will be an easy one to solve.
Cheers!
Glen
  #534 (permalink)
Old 05-19-2022, 06:44 AM
1795's Avatar
Glen,
Have you placed the battery box in the passenger footwell and tested for fit with someone sitting in the seat? I have the battery in the same place on the race car, and when I take people out for a ride to the false grid or around the track, their knees are just below their chin.
Jim
  #535 (permalink)
Old 05-19-2022, 11:59 PM
xb-60's Avatar
...Have you placed the battery box in the passenger footwell and tested for fit with someone sitting in the seat? ...
Jim,
Yes, have placed the battery in the footwell, and there is adequate room for my legs. I'm 6'2", and I would be comfortable sitting in the passenger's seat with the battery fitted in the footwell.
Here's a pic of the footwell. I'm sitting in the passenger seat and I have to stretch my feet out - with my legs straight - to touch the front of the footbox.
Remember, he [Cobra] is RHD. No battery in place, obviously.
I remember thinking some time ago that, because of the depth of the footbox, I might need to provide a footrest of some sort (like the "flipable footrest" fitted to Datsun 240/260Z's passenger side).
If I do mount the battery here, I will provide an angled footrest panel (easily removable for battery access).
Will post pics if that's the way it pans out.
Cheers!
Glen
  #536 (permalink)
Old 05-20-2022, 01:00 AM
I had to look that up, since I knew my 240Z didn't have those, it was an option! I can see where they would have been nice, I know most of the women I dated back then, had trouble with no foot support. On the other hand, I took a friend who was 6'4" to pick up his car, he said, "I can't fit in there!" I told him to shut up and be grateful! Of course once he got in, his feet were comfortably on the firewall. He said he couldn't believe how much room there was. Cheers, Dennis
xb-60 likes this.
  #537 (permalink)
Old 05-27-2022, 03:37 AM
xb-60's Avatar
Default battery re-location and "footrest"
OK, near end of the week, and thoughts turn to ....the battery mounting
So, already established that I have more than adequate room in the passenger's footwell, enough to be able to hide the battery in there.
I added - with not a little amount of time consumed - a small platform for the battery to sit on. Didn't want it sitting on the floor for a number of practical reasons.
So, this is what I came up with....
Then, pulling out the 'vice bender', made up an easily removable panel to hide and safeguard the battery.....
Here's the footrest sitting in place. Four screws to easily release the panel from the angle bracket behind it for access to the battery....
Cheers!
Glen
  #538 (permalink)
Old 05-27-2022, 04:52 AM
1795's Avatar
double post.
  #539 (permalink)
Old 05-27-2022, 04:59 AM
1795's Avatar
Glen,
Looks great! Nobody would even know that the battery is there. But with that cover in place, how is your passenger going to be able to experience the pleasure of placing both of their feet on the battery terminals as you accelerate ? You're denying them the true "jolt" of your cobra.
Jim
xb-60 and Harpoon PV2 like this.
  #540 (permalink)
Old 05-27-2022, 05:33 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Don’t forget to include a battery acid mat under the battery And terminal protective rubber boots should someone pushy too hard on the battery box cover.
Blas
SPFWiringDiagrams@Comcast.net
