February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree99Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 1.00 average. Display Modes
  #121 (permalink)
Old 12-19-2020, 08:24 AM
And if you have a really sharp eye you will see that Bob P. actually labeled that ground wire as "66" and, sure enough, if you go to the ERA wiring instruction manual you will see that connection 66 is titled "GROUND FOR FUEL FILLER PIPE" and that black wire leads to the rear bumper bracket ground point.
  #122 (permalink)
Old 12-19-2020, 09:38 AM
Default ... and what are those three small clear hoses for?
  #123 (permalink)
Old 12-19-2020, 01:33 PM
DanEC's Avatar
The street cap is a little different although end result is the same. Mine is turned towards the outside and hard to see but I’ll see if I can get a picture of it.
ERA 782 Running
  #124 (permalink)
Old 12-19-2020, 04:02 PM
Gaz64's Avatar
Originally Posted by cobrakiwi View Post
Is this the vehicle you have seen many fires in because of no fuel neck ground strap?
I see that this vehicle had a call back for a possible fire hazzard due to a faulty alternator wire etc.
I did a Google on it but coming up with nothing, would you have a link to a news report or something backing your claims?
Thanks much.
It took a few complaint instances for Holden to work out what was happening.
Then the rework techline came out to add the ground strap to affected vehicles.
Unfortunately, I can't locate the techline copy right now. I could have a hard copy of it to scan, but I need to did some old books for that.
Suffice to say, if you google "fuel filler pipe ground", you will see many instances of what can happen without the ground strap connected.
As Patrick has said, the strap is to ensure the filler neck flange (this is the point of contact by hand and fuel bowser nozzle) is held at the same potential as the rest of the metalwork.
Gary
  #125 (permalink)
Old 12-20-2020, 12:46 PM
DanEC's Avatar
Dan
Would you have a picture of how ERA, or you have added the wire to your fill cap neck?
Thanks
Well, I keep forgetting this is the only auto forum I can't post pictures too anymore because I don't have a photo storage account any longer and can't paste from my computer. Basically ERA tacks a threaded stud to the down pipe section coming off the filler and a ground wire going underfloor to the frame or the tank. If you would like me to email a picture pm me your email.
Dan
ERA 782 Running
  #126 (permalink)
Old 12-20-2020, 01:10 PM
Dan
This forum gives you like 100 megs of space to upload pics and I just looked and you haven't uploaded even one. Just click on the camera icon under your name on any of your posts and then choose "Upload Photos" from the upper right of the screen. It's really easy. I mean, really easy.
  #127 (permalink)
Old 12-20-2020, 04:30 PM
DanEC's Avatar
Yeah - I haven't used that - keeps wanting me to resize my files. Everything's a frickin pain in the ass.
ERA 782 Running
  #128 (permalink)
Old 12-20-2020, 04:54 PM
xb-60's Avatar
Originally Posted by Gaz64 View Post
....the strap is to ensure the filler neck flange (this is the point of contact by hand and fuel bowser nozzle) is held at the same potential as the rest of the metalwork.
OK. I'm convinced. My fuel filler needs a grounding connection.
Gary, does a braided strap have any advantage over an insulated wire?
Glen
  #129 (permalink)
Old 12-20-2020, 05:21 PM
Gaz64's Avatar
Glen
I don't see any advantage, one over the other.
Either one will produce near zero ohms.
It doesn't need to be over-engineered, so no Sydney Harbour bridge. Lightweight and functional.
Gary
Gary
  #130 (permalink)
Old 12-20-2020, 06:23 PM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
I wonder how all the motorcycles etc with steel and aluminum rubber mounted fuel tanks get away with out ground straps and not bowing up at the pump?
Like I said, the video in the previous post (95) says it all.
  #131 (permalink)
Old 12-20-2020, 06:54 PM
Gaz64's Avatar
Yes, that is a good question.
Now I'm off to find the answer, maybe.
Similar scenario in boats:
https://www.rib.net/forum/f36/ground...ank-42459.html
Gary
  #132 (permalink)
Old 05-01-2021, 01:29 PM
cobrakiwi's Avatar
Been a minute or two but back on this one, got the clutch and brake pedals made up and installed.
  #133 (permalink)
Old 05-09-2021, 06:51 AM
cobrakiwi's Avatar
Cover plate for around the pedals made up and installed.
  #134 (permalink)
Old 05-09-2021, 01:56 PM
1795's Avatar
Looks nice. Another happy customer Craig.
Jim
  #135 (permalink)
Old 05-09-2021, 03:51 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
You do nice work.
I like the seal for the pedals. I put something similar in the last ERA. This build is going to look more like what you did.
John
  #136 (permalink)
Old 05-09-2021, 08:04 PM
xb-60's Avatar
Very nice work Craig! I'm feeling like I should be reworking my pedals somewhat
Cheers!
Glen
  #137 (permalink)
Old 12-17-2021, 04:11 AM
cobrakiwi's Avatar
Finally got a front corner on this one, been waiting on a part of two
Then top it off with the shinny bit.
FFR428 likes this.
