1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
31 |
107Likes
11-06-2020, 01:59 PM
CA
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
Looks amazing. I hope it runs as good as it looks.
11-11-2020, 04:33 PM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Valley Plate
The valley Plate installed, Notice the IAC design... cool stuff
11-11-2020, 09:01 PM
Registered User
That is outstanding work.
Regards Mando.
11-12-2020, 08:05 AM
Abnormal CC Member
PA
https://acronyms.thefreedictionary.com/IAC
I think "Idle Air Control" seems more likely than "I Am Confused" or "In Awhile Crocodile".
11-12-2020, 01:09 PM
CA
Originally Posted by 1ntCobra
sorry, I thought this fourm was for car guys...
11-13-2020, 08:04 AM
NH
Not to steel your thread, look at the differential thread as it might save grief later down the road.
Just a heads up....
11-13-2020, 05:57 PM
CA
Just a heads up....
huh? differential thread? please post a link...
11-14-2020, 12:46 AM
CA
Cobra Make, Engine: SPF832, 466cid
KMS Differential Questions
11-22-2020, 01:05 PM
CA
while I am sitting here patiently waiting for my mainifold they move at a snail pace in new zeland... I decided to replace the cheap hardware bolts (screws) in my drive train installed by the "sub contractor" for hillbank. I was advised by John Bessy and Mooris here on CC to check what was installed in my car and sure enough Im glad I checked. Here is a couple photos oh what I found installed.
The screw on the left is what was installed, the AN bolt and jet nut on the right is what I installed.
11-22-2020, 02:44 PM
SA
....they move at a snail pace in new zeland...
Could it possibly be that there are very few flights from NZ to SF at the moment ?
11-22-2020, 02:48 PM
No, they moved at the same pace last year at this time. They have two speeds: Slow and Slower.
11-22-2020, 03:06 PM
SA
Can only call it as I see it....I've done business with companies in New Zealand over quite a few years (I'm in Australia) and they have always been rapid with freight deliveries.
Cheers, and good luck with your delivery Mike,
Glen
11-22-2020, 03:19 PM
Australia to New Zealand is like New York to Phoenix. Should be same day, or next day at the latest.
11-22-2020, 03:39 PM
SA
Patrick - there's currently a pandemic.
Global shipping/transport is somewhat affected.
Hey...even interstate shipping is affected here because very few flights are available.
Cheers!
Glen
11-22-2020, 04:17 PM
Cheers!
Glen
Patrick is still bunkered down in his basement, which is pre-pandemic behavior. He probably has no idea that there is a pandemic and how airlines have cut flights, laid off employees and shipping times have risen.
11-22-2020, 05:14 PM
And just where have you been?
11-23-2020, 01:43 PM
Abnormal CC Member
PA
RodKnock? He probably just got back from a spy mission to see what is in Evan's garage these days.
11-23-2020, 02:35 PM
I'm over on the Hummer forum now, waiting for the new EV version to hit the dealers.
I occasionally lurk around. I just don't post that often anymore.
11-23-2020, 02:38 PM
CA
I got charged $975 to ship a manifold from NZ to CA... They are blaming shipping costs on covid...
11-23-2020, 04:08 PM
Cobra Make, Engine: Hi-Tech
That seems very steep. I will tell you that I was amazed when I found out how much freight is shipped on commercial airlines every day. With the reduction of flights / airline travel, freight capacity has been significantly reduced. I have seen air freight costs increase by over 100% on a regular basis, if you can even find a plane to put your shipment on...
