February 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28
Like Tree32Likes
  #41 (permalink)
Old 06-13-2023, 02:17 PM
twobjshelbys's Avatar
I have often wondered what will happen when Peter, Bob, the Kirkhams, etc. hit retirement age. It's not a business you step in to if you haven't been groomed for it and have a passion.
The reality is the industry will simply fade into oblivion. One recently (Hurricane?) closed shop and so far has not found a buyer. That will happen to those that don't have a large enough following AND a cost effective manufacturing system.
The remaining will survive until the manufacturing costs of running continually lowering volumes essentially price the cars out of competition.
It doesn't bode well, but it is how commodities work.
Tony
CSX4005LA
  #42 (permalink)
Old 06-13-2023, 02:42 PM
Originally Posted by twobjshelbys View Post
It doesn't bode well, but ...
... but it makes my side curtains worth more.
  #43 (permalink)
Old 06-13-2023, 05:19 PM
Cobra Make, Engine: era#671 Keith Craft Motor
Thats like a Corn dog without the corn or an Icecream Sundae without Fudge .....You gotta have the outboards on an ERA
WTF? That's the nicest part of an ERA.
  #44 (permalink)
Old 06-13-2023, 05:29 PM
Or a fungus without the fun.
  #45 (permalink)
Old 06-13-2023, 05:37 PM
That would just be Gus who isnt Fun
  #46 (permalink)
Old 06-13-2023, 07:14 PM
xb-60's Avatar
The reality is the industry will simply fade into oblivion....
Does that translate to our Cobra replicas then appreciating in value, as there would be a finite number of replicas?
  #47 (permalink)
Old 09-30-2023, 02:22 PM
GOT THE CAR!!! 2 weeks ago lol. Everything is inventoried and i have started putting the suspension together. So far so good!
  #48 (permalink)
Old 09-30-2023, 02:28 PM
Started building the rearend, i went ahead and upgraded to vented rear rotors and i think i am going to try and add an upper trailing arm like the era rear for added stability. It was a bear to get the rear together but woth it....looks awesome! Although it wieghs as much as a planet.
1985 CCX and mvanhorn8893 like this.
  #49 (permalink)
Old 09-30-2023, 02:33 PM
You mean the one that attaches to the top of the aluminum uprights and goes over at an angle? That will be tricky with the Jag based rear.
  #50 (permalink)
Old 10-07-2023, 10:47 AM
Got all the front suspension and brakes on, finished the rear suspension with brakes. Also just mocked up the rear fender flares to get an idea of what it will look like. I think once they are molded in and the wheels and tires are on it will look killer. Sent the wheels to get powder coated as well....burnt brinze.
Next step is i need to remove the fuel tank so i can modify it for EFI. Thinking i will add the standard 10 bolt fuel cell ring so i can use an aeromotive/fuelab/holley drop in fuelpump.
This is turning out better than i expected.
  #51 (permalink)
Old 10-07-2023, 04:16 PM
Got the fueltank out, need to figure out what pump configuration I want to go with then map out how I want to run the lines.
  #52 (permalink)
Old 10-09-2023, 09:21 AM
1985 CCX's Avatar
Really like your style.
  #53 (permalink)
Old 10-17-2023, 07:21 PM
Got some more parts in, tkx, tilton clutch and throwout bearing, lakewood bellhousing and engine trans mounts. Goong to get the bellhousing and trans cerakoted and hopefully get the engine/drivetrain installed this weekend.
Still waiting on my fuelpump and fuel line parts. The fuel setup is going to be pretty custom. I am running an EFI setup so need a return, not a lot of room for the feed line much less for a return as well. Hopefully i can make my setup work.
Harpoon PV2 likes this.
  #54 (permalink)
Old 10-20-2023, 09:49 AM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
You will love the Tilton clutch !
  #55 (permalink)
Old 10-20-2023, 10:09 AM
Got the fuelpump setup and associated parts in today. The tank is out and i am going to start fabing up the fuel system. The fuel pump is actually 2 pumps, 1 lift pump and another in the surge tank. Is it overkill.....yeah...do i care......no. going to run stainless feed and return lines. Finding space to run the lines is the hard part. I have a plan though.
1985 CCX likes this.
  #56 (permalink)
Old 10-20-2023, 04:57 PM
Buzz's Avatar
Awesome build! I love the lean, sleek look of the flared 289 racers; far more so than the USRRC/FIA cars with the cutback doors. Keep the pics and the updates coming!
Tropical Buzz
  #57 (permalink)
Old 10-21-2023, 07:22 PM
Done modifying the tank, just need to weld it in. Going to try and finish all the welding and prep it for paint, then put the pump in a d make the hard lines. Hopefully have the fuel system wrapped up this week.
1985 CCX and Harpoon PV2 like this.
  #58 (permalink)
Old 10-22-2023, 02:18 PM
Fuel tank fab done, waiting on one more fitting and then i can finish it up. Going to 3d print some bracket to hold the linea in place (vibration) and make a wiring harness for the pumps. Slowly moving along.
  #59 (permalink)
Old 10-22-2023, 06:54 PM
xb-60's Avatar
I haven't kept up with 3D printing lately - what metals can be 3D printed now?
Very professional looking job on the tank and setup, btw
Cheers!
Glen
  #60 (permalink)
Old 10-22-2023, 07:36 PM
3d printers have come a long way but i will be using carbon infused plastic material PAHT-CF. Its good to 400degrees and strong enough for what i will be using it for.
Thanks, trying to engineer it for easy access later. I uave learned from my previous projects...your going to uave to tale it back apart at some point, try to make that process easier.
