Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
December 2024
Old 04-16-2012, 02:17 PM
Cobra Make, Engine: Dax Tojeiro, 450bhp 383 ci Stroker, Tremec TKO and Contemporary CCX, Big Block Ford, old school.
Default Propshaft UJs
Hi all, can anyone identify or confirm what the Contemporary propshaft UJs are?
If they are XKE they are probably Hardy Spicer HS166 or GUJ117 or QH2104 or Jaguar C8405. (all the same I think)
Before I go and order the wrong one can anyone confirm?
Many thanks
Kev Davies, Wales (UK)
CCX-3-4028.
445 ci Ford FE
Old 04-17-2012, 05:48 AM
Danr55's Avatar
Check the parts breakdown on xksunlimited.com. They should provide part numbers for all of the drive system parts.
Dan in Arizona
CCX3209
Old 04-17-2012, 08:32 AM
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
I was sent the Spicer 5-1410X for mine. (Oops, I just realized you were looking for the propshaft u'js) The 1410x's are what I used on the half shafts.
Old 04-19-2012, 01:42 PM
Thanks guys,
I found it was a Hardy Spicer 1330. 27mm x 92mm.
Quite a common joint I gather.
now fitted.
The drive shaft ones are larger.
CCX-3-4028.
445 ci Ford FE
