1 |
5 |
8 |
12 |
15 |
19 |
22 |
26 |
29 |
30 |
05-07-2016, 07:10 PM
MA
Cobra Make, Engine: early Contemporary Cobra (1005), 67 Shelby GT350 with Inline carb on a Boss 302
Contemporary Cobra Top Template
Does anyone have the Contemporary Cobra top template that was supplied in the DHB kit? It locates the 15 top pins for the convertible top. If I can borrow one, I would be happy to return it as well as make a CAD layout for future reference, thanks
Art
06-15-2016, 07:40 AM
AZ
I do not have the template. It i do have a top i am going g to disassemble and use for a pattern to have a "slightly modified to fit around d the roll bar" top made. When it is do E I work be happy to send it to you.
Dan in Arizona
CCX3209
06-15-2016, 09:34 AM
AZ
I think a secret decoder ring is needed for this post.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
06-15-2016, 03:13 PM
NH
A std top should fit, just add clinch and pins accordingly? No
06-15-2016, 04:31 PM
NH
I have one somewhere Art, I'll take a rummage around when I get a minute. I measured an original I did a lot of work on and there was very little symmetry, rhyme or reason to it.
06-19-2016, 08:10 AM
MA
Thanks Dan and Nick! I measured a Shelby Continuation series when I was down at the All Ford Nationals, the first stud was 1" from the door side and 1" from the cowl side. the next 5 were 3.75" to 4" apart, then 5.5" and 7" to the center stud. There were 16 in all. Since I do not have the studs mounted, I was going to attach the Lift-the-Dot receptacles into the top first and then transfer to the body. My top has an area for the receptacles that is 2" between stitching where it is reinforced and padded. I will go with the middle and use the numbers above unless anyone sees a flaw in my plan? Thanks all!
06-19-2016, 07:26 PM
NH
That will work fine and is what I just did. I have the lift the dot punch if you need it.
Bob at ERA has some helpful tips here Fitting the top
Note the lift the dot angle at the corners because of the direction it pulls in.
06-28-2016, 12:56 PM
AZ
MAke sure when you install the lift a dot that the dot on the first location on each side points either aft or outboard.
Dan in Arizona
CCX3209
07-09-2016, 06:43 AM
MA
Nick was pointing out that the guidelines from ERA show the end Lift-the-Dot's facing forward as opposed to down with the top installed. I would think splitting the difference would have it release when pulling on the corner but I have never done this before. Nick, I bought the tool before your post, only $68.
