April 2025
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30
Old 02-25-2022, 07:19 AM
Default Hydraulic throwout bearing
I recently changed my clutch set up from a10 1/2 inch set up and an aluminum flywheel to a billet steel flywheel and a 12 inch clutch. The issue I'm having is when I changed everything a can't get the car in gear, I pulled everything apart checked to make sure I had the clutch installed correctly ( I did) and rechecked the gap for the hydraulic throwout bearing-which was correct-put it all back together and still can't get the car in gear.
New parts are as follows, new bronze pilot bearing, 12" pressure plate and clutch, billet steel flywheel, the only part that wasn't replaced is the throwout bearing,
I attached a picture of the type of pressure plate I'm using (the picture is of a 10 1/2" plate same type only 12"). Hopefully someone else may have had this situation and was able to resolve it.
BTW the throwout bearing is the old style Tilton 600 (1997)
Old 02-25-2022, 09:13 AM
cycleguy55's Avatar
You might want to post this in Transmission Talk - Club Cobra
Brian
Old 02-25-2022, 09:18 AM
Tommy's Avatar
Did you follow the instructions for setting the pedal stop so the HTOB has the correct throw?
Tommy
Previously owned EM Cobra
