Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
January 2025
26 27 28 29 30 31
Like Tree2Likes
  #21 (permalink)
Old 04-20-2010, 05:56 PM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
I was lucky. My later model Contemporary had the mounting brackets already for my new billet linkages. Yeah, expensive, and it did take a little machining to add a little necessary clearance, but it sure works well. Much stronger than stock Jag carriers. And looks slick too. As soon as I get my new camera I'll take some pics. Rich
  #22 (permalink)
Old 04-20-2010, 06:08 PM
mickmate's Avatar
Wow first post and look what he comes up with. What a great networking tool we have here huh! NFS I sent you a PM about the fixture. This is what the set up looks like without my fixture in the way.
mickmate
http://www.actoncustom.com/
Last edited by mickmate; 04-21-2010 at 08:15 PM.. Reason: trying to get the picture to work
  #23 (permalink)
Old 04-20-2010, 07:06 PM
bmwdb10's Avatar
Cobra Make, Engine: Gulf GT40 CAV137, Cobra ERA286
Hey Doug and all!
My car sits just as you see in the pic... save for a brand new "Acton" roll bar freshly painted and bolted into position. I will be under it probably tomorrow night and will try to get those pics for you.
Any of you CCX guys have any doubts about your roll bar, Nick's unit is the only way to go. So far, despite being somewhat time consuming, this thing has been abreeze to install. The chrome bar I removed, believed to be original CCX equip, was pathetic to say the least. Wall thickness of only
.080" as opposed to Nick's .120" and not even bolted in place, just slid over plugs and held only in place by the rear leg angle and the grommets. I opted for added length to meet club rulings for open cockpit cars, 2" over the top of my helmet, as I do plan on tracking it soon. I strongly suggest Nicks replacement. What an awesome job! Thanks boat loads Nick!!
Added note: Just ordered some Avons! Will report on them in a couple of weeks.
Gulf GT40 CAV137
427 Cobra ERA286
  #24 (permalink)
Old 04-21-2010, 06:00 AM
NFS NFS is offline
Registered User
Cobra Make, Engine: Contemporary 427/48 IDA
Thumbs up
This morning I found the Jig assembly! (Now that I think of it I believe I still have the instructions too)
I'll post pictures this evening if time permits.
I do have the watts linkage installed. I’ve been very busy with other projects, life, work, etc. (I’m sure all you know the drill) so the car has been sitting. This spring I want to get the car out, so I’m going to work towards that goal. Like I said previously the watts linkage is in. right now I’m working on the front ride height, and installing a rear swaybar.
NFS
  #25 (permalink)
Old 04-21-2010, 07:46 PM
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
I "rented" the contemporary jig 20 some years ago when I did my watts linkage. At first I was very happy with the watts solution, my tires were rubbing in the front of the wheel wells under acceleration and the watts linkage solved it completely. I did have one recurring problem, the bolts that attach the links to the center pivot arm would break and let the link drop into the half shaft universal joint. It would bounce on the joint at highway speed looking for a chance to lock up the rear, usually while I was trying to get to the shoulder. After breaking a couple more I laid the geometry out in Autocad and swung the arcs. It became evident why the bolts were breaking. I cut the original mounts off the frame and re-welded them in the new locations. It has been about 10 years and I have not broken a bolt. I did add springs to the links that will pull them up out of the way if they ever do break but I think the problem is fixed. If you do install a watts linkage make sure that the hub carrier if free to move up and down through it complete range before you install the shocks. If it binds in the travel the bolts will eventually break.
I have some pictures on my site that show the old and new watts locations.
http://www.edwinwhite.com/gallery/Cobra?page=1
kmn5 likes this.
In school 90% is exceptional, in life 10% wrong is failure.
  #26 (permalink)
Old 04-21-2010, 08:12 PM
mickmate's Avatar
Hey Ed that's a nice example of a CCX. You've got a good gallery there with all kinds of useful shots like the rocker oiling etc. You know already with the hardtop bar being so short and it not being connected to the car by anything more than a slip fit not to ever test it. Back to watts it looks like you moved the rear mount up and the front one down? Dave's works well and his rear one looks the same as your location.
mickmate
  #27 (permalink)
Old 04-21-2010, 09:42 PM
NFS NFS is offline
Registered User
OK, here are some pictures of the jig. I have detailed notes I took when I installed the Watts Linkage, the trick is I’ll have to find them.( LOL) It’s a very easy jig to set up and figure out. I still remember exactly what has to be done. What I can do is take pictures of the jig installed on my hubs to illustrate the use of the jig. I will be out of town for a few days when I get back I’ll take a few pictures of my setup.
NFS
  #28 (permalink)
Old 04-22-2010, 05:32 AM
mickmate's Avatar
Nice! Just a guess but the holes between the frame mounts look like they're 16" apart ;-)
mickmate
  #29 (permalink)
Old 04-22-2010, 05:49 AM
NFS NFS is offline
Registered User
Hi Nick, I believe it’s 17.75
If you look closely you can see on the spacers that are used between the watts linkage hub and the jig are both stamped 17 3/4
  #30 (permalink)
Old 05-16-2010, 03:27 PM
NFS NFS is offline
Registered User
Today I finished up making a couple of vertical arms for the rear sway bar out of stainless, I put them on for a trial fit. The whole top assembly joint where the hiem end bolt - attaches to the swaybar is very close to the watts linkage, I think too close for my liking. Tomorrow I’ll remove the rear wheels, bolt everything down attach a couple of 3/4" clamps on the bar to prevent it from moving from side to side. But ultimately it looks like I’ll have to go the Speedway Engineering bar. (Probably for the best anyway)
The pics are crappy but you know what I mean.
  #31 (permalink)
Old 05-25-2010, 03:51 PM
NFS NFS is offline
Registered User
Ok, so I got everything tightened down, I only have a 1/8 of inch clearance (on both sides) between the bolt that goes through the hiem end and the watts assembly. Also the vertical bars weren’t totally perpendicular. Removed the whole swaybar assembly, ordered a Speedway Engineering Bar.
  #32 (permalink)
Old 07-01-2010, 07:31 PM
mickmate's Avatar
Okay lads here we go. I measured the car wheel centre to fender lip and also the angles of the dog bones (lower control arms) with the car sitting level and the weight on suspension etc.
[IMG]
[/IMG]
[IMG][/IMG]
You can see I got an average of 4 deg measuring both sides.
I think you should spend some time with the height, rake, wheel/tire size etc as the stance can make it look mean and correct or something like a cartoon character version of a Cobra.
mickmate
  #33 (permalink)
Old 07-01-2010, 07:42 PM
mickmate's Avatar
Get the car jacked up and on stands remove the wheels and disconnect the coilovers.
[IMG][/IMG]
Then shim, space under the hub to get the same DB angle.
mickmate
  #34 (permalink)
Old 07-01-2010, 07:52 PM
mickmate's Avatar
I have played with my programs and come up with some brackets that fit the chassis pretty well, hopefully in the right location.
[IMG]
[/IMG]
Interesting to note the hubs on this car had been cut back to presumably give some swaybar clearance. The link is disconnected from that at the moment but we are trying to fit sway bar and watts into this set up.
[IMG][/IMG]
mickmate
  #35 (permalink)
Old 07-02-2010, 03:36 PM
NFS NFS is offline
Registered User
Nick, if you want to borrow the CC watts Linkage Jig let me know.
  #36 (permalink)
Old 07-02-2010, 07:40 PM
mickmate's Avatar
I would be really interested in the jig and the instructions. Probably quicker and easier to just measure it rather than send it, what do you think? It looks like the jig I was going to make. I am thinking if the jig and the bottom of the carrier are on the same angle they should be good. I can confirm that by going up and down with the jig to see if it keeps the same chassis mount locations.
mickmate
  #37 (permalink)
Old 07-07-2010, 08:43 PM
azfordman's Avatar
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
So Nick...you are going to do the watts "and" sway bars? Is this the way it would normally be done? Just wondering.... I'm chomping at the bit to get behind the wheel!!! Thanks for all your hard work.
"Freedom is only an illusion when the government has all the guns."
  #38 (permalink)
Old 07-07-2010, 09:00 PM
mickmate's Avatar
Hey Mark, your hubs had already been chopped back so it was made to fit a watts and a swaybar in there. That is the ideal set up and it has all been nylon bushed BTW so it just keeps getting better for you. On stock hubs I am looking at the Speedway splined end swaybar to get a little more clearance to run both. I am making one of these for a high HP CCX that has chomped a hole behind his left butt cheek right through the rear inner fender from the wheel moving forward! I really believe the big cars with monster mills need a forward back brace of some kind especially if you have some rubber that gives traction. I just looked at a Unique with the radius rods going rearward off the lower control arms on a Jag set up.
mickmate
  #39 (permalink)
Old 07-09-2010, 01:00 PM
NFS NFS is offline
Registered User
I can measure if you like or send it whatever you prefer. I can take full measurements and send them to you. Agreed swaybar is definitely the way to go, I’m installing my S E bar right now (when I can find the time).
  #40 (permalink)
Old 07-09-2010, 01:21 PM
azfordman's Avatar
Not being an expert on suspensions....what is the difference in the watts linkage with or w/out the sway bar? Nick had shown me how a watts is set up, and it did seem like a good way to go, but the sway bar, it's function, etc...I'm a bit confused on. Thanks!
