04-07-2008, 11:40 AM
AZ
Electrical Issues
Not sure if anyone else has charging issues with thier Contemporarys or not. I had an intermediate issue that would cause the voltage meter to bounce around like a fart in a skillet. Sometimes it would peg on the high side and sometimes it would just go dead.. Anyway.. I finally isolated it to a thru-bulkhead fitting on the right hand side of the firewall. The first time I checked it, it checked fine. The second time I checked it it was dead. Third time I checked it, it was fine again. I finally pulled to plug apart. There are small semi circular bayonet fittings in the connector. The bayonet fitting for the main power wire on the aft side of the connector was corroded away. If you pushed on it just right it made contact and everything was fine. If you wiggled it just a little bit and the bayonet pulled away, there was nothing. I bypasses the plug entirely by running a jumper wire from the engine bay to the foot box and the whole issue is gone.
Just a heads up for anyone with similar issues.
Dan in Arizona
CCX3209
