March 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 31
Old 07-28-2010, 03:51 PM
Default LED Upgrade to Rear Rectangular Lights
I ordered the RED 1157-R45-T bulb from www.superbrightleds.com -- they have 45 LEDs on them and are perfect for the rectangular, single bulb, rear lights that have the light vertically installed. I had the "extra bright" bulbs in there, along with the reflectors behind them, but the LEDs make a real noticable improvement. It's a five minute installation, and the turn signals work just fine. Here are some shots:
This is the bulb:
This is the OLD bulb, brakes lit:
This is the NEW LED bulb, brakes lit:
And this is both of them, LED on the left, bulb on the right, brakes lit:
Old 07-28-2010, 03:57 PM
Tommy's Avatar
Cool comparison photo. Thanks.
Tommy
Previously owned EM Cobra
Old 07-28-2010, 04:13 PM
Al G's Avatar
Cobra Make, Engine: Sold - Shelby Cobra CSX6045, 468 ci all aluminum Shelby engine
Photos can be deceiving, but in the last photo the LED light looks more amber than red. Will it look red to the driver behind you?
Old 07-28-2010, 04:22 PM
Yes, it's nice and red. All of those 45 LEDs are in fact RED. It's hard to take a picture of a lit light bulb. They also sell an amber bulb just like it, but you wouldn't want that on your rear.
Old 07-28-2010, 04:59 PM
This shot is with the sun directly on the back of the car. Left side has the LED, right side as the "extra bright" bulb. The brake lights are lit, even though it's hard to tell that on the right side.
Old 07-28-2010, 05:51 PM
Fifteen years ago (or more) Ron Francis was selling 'Bright Bulbs' to replace 1157's. I've had them since then and no one has been close enough to even see them...
Thanks. I think you have a calling as a Hand Model...
Chas.
Old 07-28-2010, 05:54 PM
Uhhh, not if you knew where those hands have been.
Old 07-28-2010, 07:10 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Were they expensive?
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 07-28-2010, 07:12 PM
$25 a piece. But ERAChas lent me the money and I'm going to stiff him on the payback, so I essentially got them for free.
Old 07-28-2010, 09:49 PM
twobjshelbys's Avatar
I asked this a week or so ago. Any problems with the blinkers?
Old 07-28-2010, 11:28 PM
RodKnock's Avatar
Patrick's hands remind of another would-be hand model:
Old 07-29-2010, 04:20 AM
No problem at all. It's just a siimple bulb change.
Old 07-29-2010, 06:13 AM
Got the Bug's Avatar
It's likely that you'd run into a problem with the blinker switch if you tried to use the LED lights in the front and back.
I switched over to the Superbright RLX-3's a couple of years ago. It was a decent improvement over the stock lights, but nothing spectacular.
Patrick - Are the dimensions of the RED 1157-R45-T similar to the stock 1157 bulb?
Doug
Old 07-29-2010, 06:38 AM
dcdoug's Avatar
Alright, I'm taking the plunge. Just ordered a pair. I have had comments that people can't see my brake lights that easily.
Are there super bright, non-LED, replacements for the front blinkers too? I just have the standard 1157s in there now.
www.partskeeper.com
Old 07-29-2010, 07:03 AM
I'm going to say that the LED bulb is just a hair smaller than the regular bulb. Here's a shot:
Today is overcast so I paid particular attention to the color, hue, and brightness of the lights. I would now honestly say that the Cobra's lights appear to be "normal," whereas before they seemed to be dim, as compared to the typical brake lights that are in front of you 99% of the time.
There are, and they are a little better than regular 1157s, and Bob P. recently posted link to one place that sells them. That post was in the last two weeks. Do you have reflectors on the inside of your trunk in your Cobra? Or can you literally just reach in and put your finger on the bulb?
Old 07-29-2010, 07:13 AM
Looks like a good up-grade, I might do this myself, thanks for the tip.
...you sure those aren't the hands of Stienfields girl friend?
Old 07-29-2010, 07:15 AM
Oh, the "man-hands" episode? That was a riot....
Old 07-29-2010, 07:17 AM
dcdoug's Avatar
I'll look for the post.
The CSX cars do not have reflectors and the bulbs are not accessible via the trunk. But with a little effort you can reach up inside the rear wheel well and remove/replace the bulb fairly easily. They are just sitting there in the open in front of the brake light lens.
www.partskeeper.com
Old 07-29-2010, 08:22 AM
OK, the ERA lights are exposed in the back of the trunk. That's good for keeping them dry, but they can be damaged by stuff shifting around in your trunk (like a can of Fix 'o Flat). Plus the 1157 bulbs can get pretty darn hot and possibly catch a towel or paper on fire. To remedy that, and to increase the brightness of the rear lights, ERA sells these polished aluminum protectors, which work quite well. I'm guessing they would fit your CSX car too and they increase apparent brightness, ehhh I'm going to guess, about 25%. They would be very easy to fashion from my pic below.
Old 07-29-2010, 08:31 AM
dcdoug's Avatar
I'll see how it looks when I get the LEDs in without the reflectors. Right now I have standard 1157s with no reflectors, so I'm thinking it's going to be a big improvement and probably enough.
I also ordered the double filament 1157 replacements to add brightness to the front flashers as well. Ron Francis Wiring had them and was referenced in one of the threads on this subject.
www.partskeeper.com
